991 GT3, GT3RS, GT2RS and 911R 2012-2019
How many 15-16 gt3's have engine replaced?
Old 05-19-2016, 12:40 AM
  #496
Macca
Macca's Avatar
There have already been some RS engine failures in Europe, a couple were even mentioned on RL.
It's true but I've yet to hear what the specific issue was on these engines (in one case it was not related to the heats but the oil lines IIRC)..,
Old 05-19-2016, 01:45 AM
  #497
doubleurx
doubleurx's Avatar
There were also several 997 RS 4.0 failures on track. It happens.
Old 05-19-2016, 07:54 AM
  #498
TRAKCAR
TRAKCAR's Avatar
Received 1,687 Likes on 785 Posts
Originally Posted by Jimmy-D
The 4.0 991.1 GT3 RS if fine so far( we will know in 6 months if any one really puts some track miles on it)The guinea pig was the 2014/15 that we know to this point.
Shame - YES
9xxx miles mostly track so far so good.
Right all the way in the beginning when they were just built. Haven't read anything since and it's been a year almost..
Old 05-19-2016, 08:19 AM
  #499
sccchiii
sccchiii's Avatar
There have been several RS engine replacements recently in US. No details yet as to reason of failures but from what I'm told there are no similarities so they appear to be isolated issues. I will try to elaborate once more details available.
Old 05-19-2016, 08:41 AM
  #500
TRAKCAR
TRAKCAR's Avatar
^^ thanks, look forward to get more info
Old 05-19-2016, 11:20 AM
  #501
90944
90944's Avatar
There was also a 991 GT3 RS engine failure last month in Australia when one of the cars was being test driven by a motoring magazine!
Old 05-19-2016, 11:32 AM
  #502
CALSE
CALSE's Avatar
Wow! That's probably one of the most track miles I've heard on an original motor. How often are you running up to 9k say for a sample 3-mile track loop?
Old 05-19-2016, 01:03 PM
  #503
ipse dixit
ipse dixit's Avatar
Received 12,121 Likes on 5,269 Posts
I'm putting my money on never.
#Because8800Redline
Old 05-19-2016, 01:17 PM
  #504
TRAKCAR
TRAKCAR's Avatar
^^ LOL.
Depends on the track; I do short shift as I don't feel there is a lap time advantage revving the snot out of it at each gearshift, the car has nice torque (GT2RS anyone?).. But yeah, redline plenty of times..
These cars want to be broken in on the race track me thinks..
Old 05-19-2016, 01:34 PM
  #505
Sean in Texas
Sean in Texas's Avatar
Originally Posted by bruce987
My 2015 "F" series had a major failure at TWS over the weekend. It lost power then a lot of clanking noises followed by billowing smoke at of the rear end... lots of messages being displayed ending with "oil is low" or something like that. Then the engine just shut off and wouldn't start. Towed to the dealer and was told that I had a hole in the top of the block. Now I'm waiting to see what comes next. The dealer indicated that this would be a new motor...crossing fingers.
This my second failure. Last year I had a catalytic converted melt!
Sorry to hear about that.
If I may ask, how many miles total, and how many were track? Which dealer?
Better an engine failure coming out of 3 than going into 1,2 or 7!
Old 05-19-2016, 04:24 PM
  #506
bruce987
bruce987's Avatar
I have about 18,000 miles on the car of which the first 2000 were break in... I followed the recommendations. I estimate that 300 miles are track. As you can see I drive my car daily and don't plan on saving for next owner! Oops I miss calculated my track miles... it's more like 9600 track miles! Also I use Mobil 1 0/40 Euro... I have it changed every 5000 miles.
Last edited by bruce987; 05-24-2016 at 01:37 PM. Reason: wrong calculation of track miles.
Old 05-19-2016, 08:28 PM
  #507
IvanBurns
IvanBurns's Avatar
I have a 2014 GT3 with 7,100 track miles plus 1,600 road miles. Haven't had the piston misfire problem yet.
Last week, the car went into limp mode due to a cam sensor warning. The dealer mechanics dropped the motor to check the timing and confirmed that there was a timing problem due to some wear on a spacer.
They further disassembled the engine to replace the spacer and I went in today to inspect the internals for evidence of the cam lifter wear that is the primary topic of this thread. There was some barely visible wear of the coating on several lifter arms (#3 was the worst) but it was pretty minor. The master mechanic is going to consult with Germany, but he doesn't think that it is bad enough to be judged a problem. If so, I will report back.
Just another data point for the records.
Old 05-19-2016, 08:40 PM
  #508
MaxLTV
MaxLTV's Avatar
Received 1,270 Likes on 619 Posts
Considering how thin DLC coating is, anything other than mirror-perfect surface is not a minor issue. Once it's not perfectly smooth, the wear will accelerate exponentially. Hope they get it sorted for you quickly.
Old 05-19-2016, 09:22 PM
  #509
CALSE
CALSE's Avatar
It would be great if the top end repairs and F&G motors have thicker valve lever DLC coating.
Old 05-19-2016, 09:28 PM
  #510
robmypro
robmypro's Avatar
Received 1,784 Likes on 1,027 Posts
Got some additional information while talking to the mechanic that always works on my car. He of course was concerned when he heard that I lost oil since I just took it in for an oil change. He thought maybe he didn't tighten something. Anyway he pulled the telemetry from the car that seems to confirm some of what I experienced. He said that when the catastrophic failure occurred I was doing 3500 RPM's. This coincides with what I noticed; coming out of turn 3 to 4 I hammered it and noticed that it wasn't doing much more than 3000-3500 RPM's and not moving. That's when the engine blew, I feathered the throttle thinking it just needed a reminder that we were on the track. By the time I made turn 4 I was coasting (offline) and noticed smoke coming out the back; came to a stop on turn 5. The mechanic also said that about 30 seconds prior to the failure the crank detected a knock and went into anti-knock mode, trying to adjust the timing. He thinks this is when the failure was probably starting. He thinks the issue is down somewhere in the crank, but Porsche hasn't authorized him to take the engine apart. He also said that the engine had multiple holes in the top of the block, that probably cylinder 1 and 2 let loose. He is taking pictures and said he would provide them to me at some point in the future... stay tuned... still waiting on new motor.
Sounds like a new top end will fix it right up. lol
Sorry, I know it isn't funny.
Quick Reply: How many 15-16 gt3's have engine replaced?
