Bravery Ace on her way
Got confirmation that I'm onboard the Bravery Ace that appears to have left Emden on the 25th, 19 days after the car arrived there!! After two days of seeming to stop at every port in the English Channel she's now in the Atlantic off the NW tip of France making just over 12 knots. I wonder if the Capt could use a bit of launch control to get here a bit faster? :roflmao:
Strimdog, did you get aboard too? Anyone else? |
:cheers::cheers:
That's a much better name than Dong-A-Metis
[QUOTE=Ducati1199;12076606]Got confirmation that I'm onboard the Bravery Ace that appears to have left Emden on the 25th, 19 days after the car arrived there!! After two days of seeming to stop at every port in the English Channel she's now in the Atlantic off the NW tip of France making just over 12 knots. I wonder if the Capt could use a bit of launch control to get here a bit faster? :roflmao:
If the Capt. uses launch control he might run into Apollon Leader, which left on the 23rd and mine is on it. :evilgrin: |
Which port is your car heading for?
Halifax
Ok - you're gonna beat up to port!! We'd need launch control and 9k rpm all the way to Houston to pip you!!
Need some help
Bravery Ace discharged at Baltimore and now "vessel finder" shows it's going to Brunswick? I need it to get to Houston!! Does anyone have intel on the ports the vessel is supposed to be going to before it gets to Houston and what's its Houston ETA? Thanks,
Nearly there!!
Just been checking the Port of Houston arrivals list. Looks like Bravery Ace set to pip the Goodwood in by a day. Both heading for berth 25 with one other vessel sandwiched between the two. Also appears no other vessels on or heading to berth 25 so hopefully giving quick off load times.
