Oil Analysis - Viscosity Question
I just received my second oil analysis. First analysis was done when oil had around 4000 miles, second analysis was done around 3800 miles. First analysis was Mobil 1 0w40, second analysis was Motul X-Max 8100 0w40. Two different oils. Both times, oil viscosity came in lower than expected (61 and 10.5 where they should have been 65-75 and 11.6-14.5). The fuel and antifreeze amounts are nonexistent. All other metals are excellent, all below universal averages.
Blackstone's explanation is this engine might be just shearing oil and they say this is okay. I searched the forum for similar issues but apart from a 997 mezger engine shearing oil, I didnt find any here in the 9A1 engine. Wanted ask for everyone's opinion. |
I’ve read that Mobil 1 0-40 does tend to shear over time.
Originally Posted by Mike Murphy
(Post 17739444)
10.24 became 10.52 and 60.1 became 61.1. Not the improvement I was hoping for. |
Before anyone recommends 5w50, my car’s user manual only says to use either 0w40 or 5w40. There is no more 5w50. My car is a 2019 GT3RS, its not an OPF car either. I’m not sure if 5w40 would make a difference.
I drive the car year around including cold temps as low as 20-30F (but not lower). It is kept in garage that never goes below 45F but I cant guarantee that there will never be a day where I might have to park it outside in a super cold day and start it. |
Liquid Moly LEICHTLAUF HIGH TECH 5W-40 |
Originally Posted by SmokinGTS
(Post 17739845)
Liquid Moly LEICHTLAUF HIGH TECH 5W-40Is 5w40 ok to use in my ambient temp environment? |
As a control, what is the viscosity of a virgin sample of both oils? Might be useful to check that before blaming the engine. If it truly is shearing a bit, is this clinically relevant at such a short OCI?
I can try to do this. I was looking at my oil reports of the C7 ZR1 that uses the same 0w40 Mobil 1 oil and its viscosity numbers are also low, borderline above minimum (11.4, 11.2, 64, 64,5, etc).
Since the 5w50 has been dropped from the manual, I dont know what other option I have other than changing the oil every 2,000 miles? Is 5w40 better than 0w40 in this regard? Any way to know how much better its viscosity is? I also read in various threads that people say “if ambient is 50F or more use 5w40”, why is this? The manual says -25F or more. Thats a big temp difference. |
(Post 17739845)
Originally Posted by 3-Pedals
(Post 17739902)
Does it have better viscosity then Motul?
Is 5w40 ok to use in my ambient temp environment? What you have to remember is, with only 2 oil changes, is that you still have a lot of the factory fill Mobil that is very prone to high temp & high pressure sheer. Motul did a reformulation a few years ago and their viscosity breakdown is similar to Mobil's. Many times different oil brands don't play well with each other. Their additive packages fight each other, and show poor results for a couple oil changes until the cross pollination is removed/reduced. If I were you, I'd try to find a way to use Mobil 5W50 (A40 approved) or switch over to the Liqui Moly. Also reduce your OCI (oil change interval) to about 2,000 miles until your viscosity numbers improve as the factory Mobil and Motul wash out. As the UOAs improve, slowly increase your OCI. |
Here’s my UOA on a 2018 GT3 6MT. This is with 3,466 km on this oil, about 11 months. Does this simply mean that there’s no shearing and the viscosity is within limits or that I am changing it too soon? I think it would be important to do a before/after UOA on oil from the same bottle to be sure the viscosity drop is due to the engine.
https://cimg0.ibsrv.net/gimg/rennlis...109d0b674.jpeg |
Originally Posted by shahrukh_bakar
(Post 17741896)
Originally Posted by LexVan
(Post 17740381)
I like this recommendation. For clarity, use the 4100 since it's A40 approved. The #4010 is C40 approved for our new 992 GT3s. I just ordered 10 liters from FCP Euro and will hand carry to my dealership in early November for an oil change prior to winter storage.
The 5W50 and 5W40 are both good to -13 degrees. Colder than -13 requires 0W40. And not many here do that! LOL:) What you have to remember is, with only 2 oil changes, is that you still have a lot of the factory fill Mobil that is very prone to high temp & high pressure sheer. Motul did a reformulation a few years ago and their viscosity breakdown is similar to Mobil's. Many times different oil brands don't play well with each other. Their additive packages fight each other, and show poor results for a couple oil changes until the cross pollination is removed/reduced. If I were you, I'd try to find a way to use Mobil 5W50 (A40 approved) or switch over to the Liqui Moly. Also reduce your OCI (oil change interval) to about 2,000 miles until your viscosity numbers improve as the factory Mobil and Motul wash out. As the UOAs improve, slowly increase your OCI. With that said, I have a question about 5w40 oil. If the first number is only the viscosity in cold then wouldnt a 5w40 and 0w40 shear the same amount and be the same oil? Furthermore, an engine has probably the worst metal wear in cold start. Wouldnt you want the thinnest but safest oil during cold starts? Or 5w40 oil is simply a thicker oil and will shear less? I also dont know anything about liquimoly. Are they better than Motul? And if I switch oil brands, wouldnt this cross contamination issue you raise will even be worse since now there will be 3 oil that were switched? |
Originally Posted by 3-Pedals;[url=tel:17742123
17742123]
And if I switch oil brands, wouldnt this cross contamination issue you raise will even be worse since now there will be 3 oil that were switched? One way to solve that problem is to buy twice as much oil as you need for the oil change, but just one filter. Perform the oil change while the engine is still warm, not changing the filter, and then run the engine for a minute or two with the fresh oil. Rev the engine a small amount to not more than 3,000 RPM occasionally during this time. Perform 2nd oil change, this time, changing the filter as well. The engine will have such a small amount of residual old oil that a variance of contamination won’t show up on any UOA test. |
(Post 17742123)
I was never very good at Chemistry in school…😄 I think both Motul and Liqui-Moly are excellent. Motul is French and Liqui-Moly is German - kinda like comparing wines… |
I read through all the tech data and see that the liqui moly viscosity is somehow lower than both 0w40 and 5w40 and the motul 5w40 viscosity is quite a bit higher (14.2 vs 12.9) than liqui moly. I dont know if Motul simply shears quicker and drops to 10s whereas liqui moly stays at 12.9.
