Yes i run the 265s on the stock wheels as well. I usually run around 2.0-2.5 negative camber all around on my GT3.
I assume these are 265/35/20 on 9 or 9.5? What is your accompanying rear setup? (325/30/20)?
Trying to make a set of 20 x 9.5 and 20 x 12 wheels work on my GT3, not sure if I'll rub on the front, since 245 is likely too small for 9.5. Unless I'm running N spec tires, I doubt 245 or 305 would fit these wheels.
