orthojoe 991.2 RS at Thunderhill and track talk
#31
Platinum Dealership
Joe the issue I had on the dunlops on my old GT4 is that the center of the tire would get chewed up. Impressed you made it through that many sessions without chunking
#32
#34
I have the Dunlops on my 991.2GT3 and driving at Oulton Park Circuit on friday..In contrast to what you say some more experienced track guys here in the UK much prefer the new Michelins to the Dunlops..They say that the Dunlops don't last as long for hard track use..I personally like the Dunlops however i'm no expert by any shot.The general consensus here in the UK (Wet place) is the Dunlops are better in the wet and cold..Any thoughts Joe..?
I enjoy reading Joe's track experiences and have learnt a lot from him..
#35
#36
thanks for a very informative thread, i ran my .2 3RS today, on Cup2's that have seen better days, i was getting a lot of both entry and exist oversteer, bars are set at medium front and rear, i need to check the Rake, and am being lazy, does anyone have the factory data for the 991.2 3 RS and the measuring points? getting even tire wear across both ends on factory spec.
#37
I moved over from the MPSC2 N1 to the “new” Dunlop race2 exactly 1 year ago.
We tested the two tyres back to back - new for new. I did about 60 laps of a GP circuit and this was the result:
1. 7 of the top 10 times were on the Dunlop.
2. The fastest three times were on the Dunlop.
3. The fastest Michelin time was 0.3 sec slower than the fastest Dunlop time. (On a 1m 40s a lap track)
The Dunlop Race 2 is nothing like the Dunlop Race 1.
I have not tested the MPSC2 N2 or R. All tests seem to suggest the N2 is a harder compound and the R is much softer, which won’t help me to much in tyre restricted Tarmac rallies. The Race 2 seems “just right”.
I have now done several hundred race km on the Dunlop race 2 and the wear and consistency over the life of the tyre is impressive.
I actually think it is better in the wet than the N1.
so, while there is not a lot in it - I think the Dunlop is perhaps slightly quicker, but it’s the wear and feel that I enjoy about it. As you mentioned, Joe - it does slide a little earlier but it’s more predictable on the limit. I’ve also found the hot pressure working range is wider. It still offers awesome grip at 38 psi.
my 10 cents worth.
my 10 cents worth.
#38
my 10 cents worth.
my 10 cents worth.
My only concern now is that it will be harder to get this tires if people start to believe us. Lol!
#39
#40
Platinum Dealership
Heat cycling is a much worse handling variable than tread depth. The heat cycled tire has a harder outer surface and therefore never grips up...I'd rather have a tire that wears down and stays consistent down to the cords.
#41
thanks, suspected this was the issue, new set of dunlops (Race 2's) on the way to be fitted next week. Will report back on the difference
#42
#44
Originally Posted by DRE168
Great video.
Have you got your SOLO 2 DL connected to ECU via OBDII or CAN? I was told to attach via OBDII but I can’t seem to log braking.
Cheers.
Cheers.
1). Are you connected via the Porsche specific obd2 protocol and not the generic obd2
2). Transmission. You can only get brake pressure via obd2 if you have pdk. If you have manual transmission, you need to connect via CAN if you want brake pressure.
#45
Received 1,270 Likes
Thanks! I'm connected via obd2. 2 things to consider:
