Rennline rear tie down help
Has anyone installed the rear tie downs on a 991 GT3? I had the car on a lift and I'm not sure exactly which bolt I'm supposed to remove to mount the tie down. Any help would be appreciated. Thanks!
Mike
Mike
Basic Sponsor
Mike here is a screenshot that might help, you will want to remove these 2 bolts by the rear cross-member to mount the rear tie downs.
Hi,
A little bit OT but I have bought Rennline Tie Downs, one for the front of my 991 GT3 RS and one for the rear. The big problem is that for the ROW cars, the rear Tie Down is to short becouse the license plate is still mounted. Is it possible to do one that is somewhere between the short and the long one?
My two Tow Hooks, one for front and one for the rear
The rear of a ROW 991 GT3 RS
The rear of a US 991, must remove license plate to mount it.
Basic Sponsor
I just want to clarify those are the Tow Hooks pictured above and not tie downs and should be used for pulling in a straight line only. That being said for the ROW cars the rear Tow Hook is designed to be mounted vertically as opposed to the horizontal position on the US spec rear bumpers. To install you will want to install the screw first, and add the hook after.
Sorry for my english - Tow Hook is what we are talking about.
I can take a picture tomorrow but if I install my screw first, it is not space enough to fit the hook becouse the screw is going to long inside the bumper - and use all threads.
So if Rennline can produce a screw that are someway between todays long and short screv it will fit perfectly to ROW cars.
Very welcome. Also make sure they sit flush and don't hit the cross member while you tighten them on.
