991 GT3, GT3RS, GT2RS and 911R 2012-2019
2018 GT3 front axle lift system
Old 04-21-2018, 09:54 PM
  #46
Dalema
Dalema's Avatar
I don’t have it, any haven’t had any issues to date. I did scrape the bottom of the plastic part a little first go into my driveway, but haven’t since. Live and learn!
Old 04-21-2018, 10:22 PM
  #47
BlueGT3
BlueGT3's Avatar
Another front axle thread....
I have had on my last two GT3s, use it all the time. Some will say the opposite.
Old 11-12-2018, 06:41 PM
  #48
nimprojects
nimprojects's Avatar
Sorry if this has been posted before (I promise, I did search)… Does anyone know the maximum incline (up and down) you can handle without scraping when the lift is up?
Have a 991.2 GT3 coming, and there's an apartment building I'm looking at with a quite tight, slopped garage entrance (about 12°). Would be really annoying to buy a place that I can't get my new car in and out of. : )
Many thanks if anyone knows this.
Old 11-12-2018, 07:10 PM
  #49
GT3
GT3's Avatar
Not sure regarding degrees. But in in Florida, which is flat, never needed the lift before with other GT3 since I lived in a house. Now live in a highrise building, and could not do without the lift, especially by the gate. Even when coming diagonally it almost scrapes with the lift raised....
Old 11-12-2018, 08:03 PM
  #50
pearlwhites
pearlwhites's Avatar
I wished my R8 had it every time I pulled into my driveway so I spec’d it on the GT3. Scraping sounds cause more psychological damage than the option price.
Old 11-12-2018, 08:21 PM
  #51
chance
chance's Avatar
19.5k miles on my 16 used almost daily, ordered it on my 19.
Old 11-12-2018, 09:40 PM
  #52
sampelligrino
sampelligrino's Avatar
better to have it and not need it than need it and not have it IMO, its a must have for me since I try to drive and use my GT3 for all occasions. I would stress more over whether its worth it to take the car out if I didn't have the lifter, this car sits insanely low to the ground (racecar)
Old 11-13-2018, 12:28 AM
  #53
ScratchTheItch
ScratchTheItch's Avatar
I have the lift and STILL scrape at the bottom of my driveway. Couldn't imagine not having it.
Old 11-13-2018, 12:55 AM
  #54
nimprojects
Thanks for all the replies.
Yeah, I consider the lift essential on a GT3 as I’m in NYC. I have the sport suspension on my 991.2 4S and occasionaly wish I had the lift (most of the time it’s totally fine) so will definitely need it on a GT3.
My concern is even with the lift I won’t be able to get the car in and out of this particular building. 😬
Old 11-13-2018, 01:00 AM
  #55
mr965
mr965's Avatar
Buy a spare front spoiler even if you have front axle lift. You WILL need it.
Old 11-13-2018, 01:53 AM
  #56
1963SWC
1963SWC's Avatar
I have time tomorrow so if no-one has answered your question by 9am CST, I will post you a reply. But, please help me understand what exactly you are looking for-
1) Approach angle (90 degrees to slope) with lift down and 2) approach angle (90 degrees to slope) with lift raised? Once I have the protractor out and some strings pulled, I can easily measure the max incline and see if 12 percent is doable. Will measure front lip height at each position as well so we will know what size random road debris we can clear....
The nose is just so long and the car so low that the approach angle is going to be shallow; the front tires arrive at the slope too late to assist in many cases- maybe we need a reverse wheelie bar with some rollerblade sized wheels about 6" back from the front lip....
********Edit
Had to solve this tonight- you have an issue. I have one now as well but mine revolves around me starting the car to activate the FAL with my wife asleep 20 feet away.....
Using the approach angle calculation method/calculator on the Race Ramps site; with the FAL down, the approach angle at the leading edge is 7.1 degrees. Activating the FAL and having the car lift 1.75", provides you with an approach angle of 9.9 degrees. The angles are slightly higher on the portion of the lip directly in line with the tires but you will have already buried the leading edge if going straight in. Good luck!
Old 11-13-2018, 12:21 PM
  #57
nimprojects
Thumbs up
Thank you so very much for your detailed response — Rennlist at it's best.
The way this garage is set up, I'd turning on to the ramp rather than hitting it head on, so it might work, but I suspect it'll be very close based on your numbers. Looking at it again tomorrow, so will try to take more detailed measurements.
PS: Hope you don't wake your wife up.
Old 11-13-2018, 12:25 PM
  #58
GrantG
GrantG's Avatar
Received 4,708 Likes on 2,685 Posts
Usually approaching at an angle helps quite a bit - good luck!
Old 11-13-2018, 12:30 PM
  #59
Jimmy-D
Jimmy-D's Avatar
Received 1,382 Likes on 719 Posts
Have a Mason come in and do some work for you. And if you say, illegal, no one ever knows if not caught
Old 11-13-2018, 12:34 PM
  #60
drdonger
drdonger's Avatar
I didn't have it on my GT4 and I would scrap on occasion. I didn't like having to be extra careful and turning into driveways at extreme angles. It already looks douchey enough to some with the wing, so driving slowly at an angle when people are behind you makes it even worse. I have a lift now on my GT3 and use it almost every time I drive. For me it is one of those things that if I didn't have it I would survive, but having it makes life so much easier.
Quick Reply: 2018 GT3 front axle lift system
