Multiple Electronic System Failure
My 991 GT3 experience multiple errors / failures on Sunday. The errors I am seeing are:
1) Loss of Steering Support - Increased Effort
2) Transmission fault Possible no R gear. Drive on Possible.
3) Fault of headlamps control system
4) PSM System Fault
5) Breakdown of rear steering, take care when driving
6) Fault Parking Brake
7) Fault engine control - Possible to drive on
My car is at the dealership now being diagnosed. I was told this could take several days.
Has anyone else had an issue like this?
4) PSM System Fault
Is it a new car? Are you running the lightweight battery?
I had an issue after 500km's on my RS where the car just went into limp mode in the middle of the highway, was shutting down and worked normally only at idle, whenever I tried to move forward it was cutting power and all electronics started blinking and lights going off..
Anyway managed to limp to the nearest dealership, luckily 20kms away and the reason was that my dealership connected the lightweight battery wrongly... the lightweight battery has two ports for one of the wires (not the negative neither the positive) and the cable was inserted into the wrong one, sorry not very familiar with the technical part, but anyway solved my problem.
Since it is pretty much impossible that all that stuff failed at once, it will probably be something easily rectified. Keep us posted.
If you can start the car. What's the voltage meter measure when the car is running?
