Brake squeal on gt3 CCB when hot...
So I had a 991 GTS prior to this car with the regular brakes and I had the same issue, now I know these brakes are known to squeal when cold, but on both my cars the brakes would only squeal once the car is driven for 30 minutes and warmed up. Ironically right before I traded in my gts I got the rear brake pads and a certain sensor replaced (after making the dealer do everything from changing front pads to applying anti squeal) and it worked... Now I have the same issue here and while some might try to convince me its normal, having a 155k porsche come to the same stop as a tractor trailer is a bit embarressing... anyone figure out a solution for this yet?
