Engine Control Fault
#61
Originally Posted by ChrisF
Maybe it's like the 997 RMS issue; the more they were driven - the less they appear.
#62
No ****... you'd think with all the VW BS, they would face this head-on! Transparency, my ***. Losing confidence in the brand.
2. Issue transferable 100K mile warranty on the motor
3. Give the damn specifics of the what the fix is! Quit making it a mystery.
#63
SA said its unclear what the fix is. The crankshaft apparently has an updated part number and likely point to changes. I'll call PCNA tomorrow. I doubt they will clarify the matter, but at least I'd like to get reimbursed for the 2 year service I just did that cost me $2K.
#64
@urban2k:
Maybe you postet it allready elsewhere but I didn't find the information. What engine serial number do you have? F > 30xx or G? If so... oh noooo. If below: you will get improved parts that may solve the problems.
#65
All I know is that it's an F-series engine. Don't have access to the car so can't get the serial number. I can ask my SA.
#67
Basic Sponsor
Have them check for cylinder scoring and bearing wear when the head is off, all of that metal has to go somewhere, and you don't want an engine in the car that has DLC particles embedded in the bearings and scoring in the cylinders... Another reenlisted had to push and eventually got a new G engine out of it, took a bit of effort, but they got it done. I suggest the same for you...
To all that are hopeful the G engine is immune, the design is the same as the E,F on the valve train only DLC coated, so it takes longer to start wearing the metal. The G engined cars will show this issue as well, just don't know how long it will take. There's a reason why they went from hydraulic lash adjusters, to solid lash adjusters in the 991.2 engine and this is why we're putting a lot of resources into addressing this, as I personally don't have confidence Porsche will warranty this issue once the warranty is expired...
Dundon Motorsports
Gig Harbor, WA
253-200-4454
jamie@dundonmotorsports.com
www.dundonmotorsports.com
Facebook.com/dundonmotorsports
Instagram @dundon_motorsports
Dundon Motorsports
Gig Harbor, WA
253-200-4454
#68
My engine serial number: F02947
#69
So, what about the RS?
#71
Originally Posted by Loess
Joe does your car ever smoke on startup?
The car still consumes oil on track. About 1/4 quart per track day
