E diff vs Mechanical lsd on 991.2 gt3
I was reading that the 991.2 gt3 manual trans has a regular limited slip while the pdk version has the E diff. What does this mean as far as putting down the power - the pdk car should be better right? Maybe some of the more knowledgeable guys can elaborate.
Very different system.
With PDK, the e-diff and torque vectoring, all system work together for optimal track performance, i.e. Computer managed.
With manual and mechanical diff, torque vectoring is limiting and not as good.
Why the RS, a track focused car, will only come with PDK in order to maximize track performance.
Which system use more often the brakes for little corrections?
This is very interesting if true. My only reference point is driving Evo X on ice, which I do at least once per year. The difference between the ones with mechanical diff vs electronic is astonishing, the latter just putting the power instantly where you have the grip allowing you to balance the car with incredible accuracy. The mechanical diff requires a lot more patience. It's the expert's choice, because electronic diffs are not allowed in rally's, but the difference in performance is extraordinary.
Very interesting thread.
