Anybody use PFC pads?
Been using the performance friction 11 pads for 6 months and noticed the pad is oversized for the stock rotor ring and hangs a few millimeters over the inside of the rotor. Anyone else notice this problem?
I'm developing a small fang of metal hanging off the inside of the pad as it wears. Odd thing is the car stops like a charm. No problems whatsoever. I love the way these things stop
Official word is Porsche changed some design parameters on the rotor after pfc designed the pad but no fix in sight on pfc's end.
I haven't heard of any brake failures arising out of this. Just trying to think through the implications of continuing to use the pad.
Would you guys keep using the pad or switch? Interested to hear comments. Pics attached. One is stock pad lined up to pfc pad. Other is pad wearing on rotor.
No issues for me when I had them on.
Loops, thanks for the feedback. Glad to hear no issues and makes me feel better about using the pads. As I said I've been very happy with the braking performance and would rather not change unless there's a compelling reason to.
Sean, interesting that you didn't have any issues. What year is your gt3?
I gave up on pfc. Very hard on rotors. At least the 08 compound.
Just an update. Pulled the calipers off. That little fang of metal came off easily with a couple small taps with a rubber mallet and a little wiggle of the caliper. Measured Rotor wear with calipers and there is no asymmetric wear on the inside of the rotor ring compared with the outside of the ring. Pads aren't tapering either. Piston pucks look fine. That damn brake line bracket is still the hardest thing to work around.
The 11 compound is working so well will probably keep using it till it's time for new rotors.
Here are the PFC11 pads I replaced last month. No fangs. Rotors are AP, pads and rotors bought from Apex
Again, I have a MY2015, Oct14 build, and I put these pads on ~Dec of 2015.
