OFFICIAL 991.2 GT3 RELEASE *Confirmed 500HP 4.0 & Manual option*
#706
Standard wheels are gloss Silver.
You can pay extra for the Satin finishes. Will work well on black, as the old gloss black ones showed water spots, scratches, etc. easily. A satin finish is more forgiving.
Attachment 1142640
Satin Platinum
Attachment 1142641
Attachment 1142640
Satin Platinum
Attachment 1142641
#707
RWS also has updated software I'm sure as was mentioned for the R.
Let that be true....
+1 Its fastest as well.
You'd be nuts to try after that comment by AP.
Fixed it
I recommend that you look at the silver on the 991 GT3 wheels in person.
In my opinion the silver on there is spectacular. The paint formula is not the same one as for -say- Carrera S wheels' silver. The platinum satin on the other hand is the same on gt3 and S wheels. And IIRC platinum satin was default on 991.1 GT3 and gt3rs.
In the rarity department I'm pretty sure the silver is serving better.
I have mentioned this in a post...I don't remember if on this thread or in a different one :
Please do some research online on the differences between a double mass flywheel and a single mass. The difference between the 2 is quite substantial. The crankshaft is a high precision balanced assembly. If you create the slightest unbalance in that spinning assembly,it will send vibrations throughout the entire engine at certain RPM range. In time,the potential failures could be as minor as a Rear Main Seal oil leak,to the catastrophic failure of the engine.
AP is saying this crankshaft is different : larger and has drilled holes through it. Oil is fed through those holes to the rod bearings. He also specifically said that the single mass flywheel will create vibration that will hurt the main bearing in its vicinity.
Do any of you want to be the one to try it? Go right ahead! You will be a great test bed. AP made it very easy for you : he clearly said the single mass flywheel from the R WILL FIT on this engine! Forget about warranty though and this engine is not quite proven yet. All we have is words at the moment.
Sure...all of the above could just be AP's BS and he is just protecting the R by not offering the LWFW,but are you willing to take that bet?
Fixed it
#708
Availability update: just tried one of the bigger UK dealerships. They're part of Porsche Retail rather than most others, which are franchised. They have 12 allocations for this year and all are gone. I asked what about next year? They said we won't let you join the queue as there are 50-60 people already ahead of you!
I expect premiums are going to be even higher than last time unfortunately.
#709
GET THE LIFT!
Yes - have front axle lift and use it every day. Speed humps, driveways, causeways, etc. The front of the car is very low and the lift makes a huge difference. Activates and deactivates almost instantaneously. I will post some photos coming into my driveway tomorrow to highlight the difference (pitch black outside at present!)
http://www.porsche.com/australia/mod...is/liftsystem/
And it only weighs 7kg.
http://www.rennteam.com/page/content...entId=43352085
I cannot accurately predict when the diffuser will scrape and I am not sure I hear it anyway over the sound of the engine. Compression of rear suspension coming down off a speed hump is the most likely scenario.
DM
DM
#711
they look like the tackyish graphics you often see on those stretchy slip over nylon seat savers sold by JC Whitney-type places for eveything from trucks , minivan, to sporty cars
#712
^^^ somewhere mentioned you will be able to delete them I believe? I'm sure that will be the case.
Those Alcantara inserts are easily interchangeable and they'll give you the option I'm sure to go without.
#713
I haven't called around but did have to fill out a form last week with my UK dealer to show my driver history, etc. I assume they will use this to determine who will get one. No guarantees of a car of course but at least it looks like there is a more considered process this time. Then again, may all be a smokescreen and all cars have already gone to the DP's best customers (no problem with that) and/or friends (not so good).
Did you submit a LOI last year?
#714
Can you legally import and drive in the U.K., a LHD car from India, Australia, Japan, etc?
#715
Received 1,727 Likes
#716
Get a set of cushions from 991.1 gt3 or gt4. Better yet, upholster them in hounds tooth *drool*
#717
only sl off topic : AP's " hauler " ...it's not a VW Group model like an RS6 Avant or Cayenne Turbo S , but a competing manuf product and a vehicle class mostly abhorred n Europe ...OTOH , a sign of a real " car guy " !
http://www.roadandtrack.com/car-show...yessir-indeed/
#719
#720
Step 1: get GT3 PFF for rock chips
Step 2: have houndstooth or tartan seat inserts made for LWB.
Step 3: tire stickers...
(I'll stop there)... but my point is, those inserts are $500 away from looking great.)
