New larger PCCB brakes for 991.2 GT3??
Grant, why is it that most track junkies prefer the regular brakes? I understand PCCB's are not bullet proof and cracking is an issue which generate considerable expense.
The PCCB rotors also require specific pads to work correctly (I think only one besides stock is recommended), while there is a pretty wide selection with the stock system.
Also, some people think the friction bite of the PCCB system is not as gradual and easily modulated.
Also if you hit the gravel/sand trap they are likely to chip and need replacement.
These massive 10-pot would be very heavy, seems unlikely they would put these on the gt3 no?
Panamera Turbo S Hybrid weighs 350kg more than the Turbo S at 2350kg, or almost 5200 pounds. PCCB come as standard, unlike normal Turbo S. Weight justifies brakes, even if it's making it harder to justify buying one!
I found a cut-away render of the 10-piston calipers from the Cayenne Turbo S. Interesting that there are two rows of pistons still using just 2 pads per wheel. Also seems unlikely that the pads slip out the top. Sorry for the tangent - I now doubt that these are destined for the sports cars (they were around at time of 991.1 RS launch and not used then).
I guess it's back to plan A: Iron rotors with Race Technologies (Brembo) RE-10 pads (and lots more money in my wallet).
Yeah, that thing is a tank but it also has regenerative braking which takes much of the thermal load away from the rotors. I would not be surprised to see this upgrade on GT2 RS and maybe GT3 (might become a track benefit finally)...
Also speed has much more impact on braking requirements than weight (squared function vs. just simply proportional). Of course that Pana TS Hybrid is both very heavy and very fast...
