991 GT3, GT3RS, GT2RS and 911R 2012-2019
Wingless RS till black uprights come in
Old 02-11-2019, 10:02 AM
  #91
audiophilitis
audiophilitis's Avatar
Originally Posted by nikko747
@ audiophilitis: Use 3M dp420, clean the outside of the insert and the hole with isopropyl alcohol. Put a thin film on the outside of the insert and in the hole in the deck lid. Screw the insert into the hole using a socket head cap screw or one of the wing attach bolts with a light coating of grease on it ( to prevent any stray epoxy from bonding it to the insert). Set the insert so it is a little bellow the surface. Let the epoxy set for at least 24hrs.
@ racer959: thank you.
Thank you!
Old 02-11-2019, 10:23 AM
  #92
audiophilitis
Originally Posted by John Belk
For those that like these winglets, I would imagine there’s an enterprising individual with access to a 3D printer (using a suitable media) that may produce similar results at possibly half the cost or less...since these winglets are painted, the type of material may not be relevant. Just an idea...
and a good one...agree that material need not be exotic given fact that factory NACA, fender and rear ducts are made out of plastic.
Quick Reply: Wingless RS till black uprights come in
