Cracked brake caliper piston...
#31
Prior to 991 gen cars, the ceramic pucks were a "floating" style. Although there were a good number of failures just from track use, the majority of pucks that broke tended to be from falling on the ground during a brake service. It was very frustrating to technicians because most didn't know there were floating puck replacement kits available via Porsche Motorsport but not the dealer, so they'd end up replacing whole calipers when it happened. The design then changed to a screwed in piston like we have on the current calipers, to prevent the issue of them falling out and breaking during service. Unfortunately, the lack of puck movement associated with the screwed vs floating design compounded the track derived issues, making the screwed pucks much more susceptible to deterioration after heat cycling and pad taper. Our titanium pucks resolve this issue on the 991 gen calipers, and with luck the next generation cars will have another revision to help resolve the issue. Photos below of the floating vs screwed style pucks.
#32
I'm dreading addressing this issue, but I know I've got to do it.
Vented, stainless steel pistons would also solve the issue. It pains me to say this, because I don't care for any of their other products, but Racing Brake's SS pistons for caliper rebuilds are a solid upgrade and fall somewhere in between the Ti inserts and full AP caliper upgrades.
Lots of 987 guys use them for caliper rebuilds for heavy track use or race cars using the stock calipers.
#33
I pushed and complained, got one front and one rear calipers under “Goodwill”.
This was along with a $11K service bill at 24000 miles, 12000 track.
After one track day, the new caliper 2 pucks were cracked.
BTW the 2 old calipers were much darker then the new ones, so when I permanently fixed the problem with Autoquest Ti pistons I painted all 4 calipers..
i should have skipped the goodwill step alltogether.
#34
Received 1,150 Likes
Perimeter (11-27-2019)
#36
Former Vendor
#37
Former Vendor
If you don't disagree that less component is better, RB's stainless steel pistons s/b an alternative for your OE piston replacement. Combine with our high temperature dust boots which help to shield the heat as well as brake dust from deteriorating the piston/seal due to fragile OE boots that quickly burnt out in just a few laps and left un-replaced.
Join hundreds of Porsche track & pro racers and rebuild/upgrade OE calipers with RB components, eliminating those redundant OE/aftermarket components and keep your calipers at peak performance with optimal braking efficiency.
The most comprehensive and reliable Porsche calipers rebuilding resource.
https://www.racingbrake.com/category-s/7185.htm
#38
Former Vendor
Replace OE calipers with RB track duty calipers like Nissan GTR and Mustang GT350 serious track racers did.
https://www.racingbrake.com/category-s/7548.htm
1. 100% interchangeable with OE calipers and fully compatible to OE upright for a 100% bolt on installation, no modification. (For 410/390mm pccb)
2. Caliper pistons are properly sized to have the same proportion as OE but are staggered (unlike OE @same diameter) to minimize pad taper wear.
3. Uses the same brake pads as Corvette ZL1 / Camaro Z28 CCM brakes, so a lot of choice on compounds at lower cost than Porsche dealers.
4. Calipers can take either pccb or iron conversion.
5. Calipers are made with internal dust seals (same as Brrembo built for Ferrari F430 Scuderia), so no dust boots to expose/damage.
6. Calipers have open top. Never need to remove the caliper for pad change, can monitor pad wear easily, and pad replacement is an easy and simple step.
7. Highly cost effective than other alternative yet still retain stock set up.
8. Guarantee to outperform OE calipers in braking performance and durability or your money back.
#39
#40
#43
Anyone who tracks the car should just put in the Ti pucks and be done with it.
I will see how the new .2 GT3RS holds up, I'm on my 4th set of front pads, haven't heard yet about cracks, but will verify.
#44
Interesting read, for sure. Titanium pucks vs RB stainless pistons... A full front/rear RB kit with new seals/boots and pistons is cheaper than just the pucks from Autoquest. So I'm wondering if anybody more knowledgable than me knows the pros/cons of each?
And if you wait until the OEM ceramic pucks crack, can you just change them to titanium or replace with RB pistons or do you need to replace the entire caliper? Or do people have to get caliper replaced under warranty ONLY because Porsche doesn't provide the ceramic pucks individually?
#45
IMO the titanium pistons would be a no-brainer IF they could be installed without removing the caliper and disassembling the pistons and they were more reasonably priced. But since they require full disassembly to hold the aluminum piston while removing the center bolt holding the puck in place, R&R labor is actually higher for the pucks than the full stainless pistons.
Tough call.
