garage car lifts
#391
I had to deal with Bendpak directly and I assure you that’s not the dumbest thing, if you speak to them directly it will be even worse. It was unbelievable.
#392
I had a BendPak HD-7W installed today. I was at work and not present for the install. I rushed home quickly after work to look at my new toy and boy am I disappointed with my unit. There are nicks and scratches all over! Rust has formed in many places already and supposedly this thing is brand new, although it does list a date of manufacture of January 2018. I paid for a brand new unit but candidly I'm not certain this wasn't sitting in a warehouse for 16 months and moved around a lot or if this is typical of BendPak quality? Needless to say I am not happy. I sent an email this evening to the company I purchased the unit from advising them of my displeasure. No response yet from them but glad I charged this to a credit card. Is this typical BendPak quality? If so, I will look at other brands as it's not acceptable to me. Thoughts?
edit: Siri was terrible and finger edits made it worse
#394
Thanks for the responses and insight everyone! I was not present for the install. Unfortunately I was booked with meetings and I was unable to be present. I spoke to the installer yesterday and he too agreed the condition was unacceptable. Not sure why he continued with the install when he noticed the defects! Oh well, it's his labor cost and not mine.
My installer is a BendPak dealer as they sell a lot of them here in Chicago. He did comment that BendPak has a program for $500-$700 that they will hand pack each piece to make sure it is delivered scratch free. I told him that is the dumbest thing someone has said to me in quite some time. So you're telling me if I don't pay an extra $500-$700 I should expect a scratched and dinged up product? What? Anyways, he is going to contact his rep at BendPak tomorrow to work on a replacement. Worse case is I purchase another brand that does a better job packing their goods. I paid a lot of money for a new lift. I want one that is defect free! Pretty simple ask.
Please share the photos. Are they cutting corners on how they are packaging/shipping the lifts?
#395
I have 118.25" garage ceiling clearance in our new house. I had the builder install ceiling hugging doors and Jack Shaft 8900 wall mounted openers. My lower car is 55-56" H. BendPak's spec sheet indicates I can lower the ramp to 58.1" for the lower car. Add 5" for the height of the ramps and 50-51" for my .2 GT3 (sitting on top) ending at 114" rounding up each car's height. I added 2" for the ramps to lift off the locks which gets me to 116". Can any BendPak HD9 owner's advise if they think I am missing something? BendPak now apparently offers an adjustable limit switch (add on accessory) which stops the ramps at the pre-set limit.
#396
What is the 118.25" measurement to? The ceiling or the max clearance when the garage door is up? If the ceiling just triple check because obviously you have only ~2" margin built in on releasing the locks. If the garage door (when up) then you can always lower the door to release the locks then put the door back up when you're lowering the car.
I measured soo many times and was still nervous. But it worked brilliantly.
#397
^ ILLCOMM, that's to the ceiling. I believe the door is close enough to the ceiling to provide enough room for the GT3 wing, but do need to confirm that of course. Like you I've measured over 10 times already. Measure twice, cut once as they say. Here it's measure 20 times and order once.
Did you find you were able to lower the drive on ramps to 58.1"? I believe the range 58.,1" - 59"; iircc.
Thanks so much for the assistance!
Your garage looks great. Nice stable.
#398
#399
Tried my best to take some photos. I lowered the lift (HD-9) to what I think is the lock you want to use. I measured, as the pictures show, just under 59" drive under, and just under 64" ramp height while resting on the lock.
Hope this helps.
Hope this helps.
#400
#401
Agreed. I'd like to see some pics too to compare the scrapes and scratches were on the unit I have sitting in my garage.
That said, anyone know if Challenger lifts have the same problem or do those generally arrive blemish free?
#402
I am thinking of ditching the BendPak all together and buying a Challenger lift instead.
#403
I went with the Challenger instead of the Bendpak because the dealer talked me into it (he is a dealer for both). Mainly due to not needing an Air compressor to lower the lift. They are very similar in price (I think the Challenger was around $200-300 more). I'm very happy with the Challenger and would buy it again (actually plan on buying 2 more at some point as needed).
#404
Anyone have a recommendations of a firm or contractor that could install a lift, deal with re-doing the garage rails and some garage make-over work near the North Shore of Chicago?
#405
Adam
