991 GT3, GT3RS, GT2RS and 911R 2012-2019
Axle lift install or aftermarket?
Old 07-11-2016, 05:29 PM
murph85
murph85's Avatar
Default Axle lift install or aftermarket?
I've already missed 2 gt3's by being a day late on the phone, however I recently found one I like but it doesn't have the "475" front axle lift system option. My question is would this be something I could have the dealer install or would be it wise to go the aftermarket route, I know kW made an adjustable suspension via the iPhone for 997 but unsure with the 991.
With my driveway and roads in the Boston area I think the axle lift is a must.
Thank you,
Sean
Old 07-11-2016, 05:47 PM
Haku
Haku's Avatar
Afaik, it's not a retrofit oem option.
Old 07-11-2016, 05:52 PM
golfnutintib
golfnutintib's Avatar
Haku is correct.
Old 07-11-2016, 06:06 PM
murph85
murph85's Avatar
Looks like aftermarket it is.
Old 07-11-2016, 06:30 PM
ezinternet
ezinternet's Avatar
When I looked into this for my 997 a few years ago the aftermarket version from TechArt or KW required replacing the struts and thus losing Porsche's PASM.
Old 07-11-2016, 06:32 PM
MBDark
MBDark's Avatar
You can buy a whole bunch of front lips for how much it would cost you to put it on. If you can get the car with it, great, but if not, don't sweat it and just angle up inclines.
Old 07-11-2016, 06:51 PM
OCturbo
OCturbo's Avatar
+1
Old 07-11-2016, 06:52 PM
ipse dixit
ipse dixit's Avatar
Received 10,711 Likes on 4,752 Posts
Is there even an aftermarket option?
Old 07-11-2016, 07:05 PM
murph85
murph85's Avatar
I don't believe so, maybe eventually.
Old 07-11-2016, 07:10 PM
GiuseppeM
GiuseppeM's Avatar
I have it and wouldn't have bought the GT3 without it, if you have a garage that requires it you're gonna hate not having it every single time.
Old 07-11-2016, 07:11 PM
ipse dixit
ipse dixit's Avatar
I think for those that say just buy a bunch of front lips and replace as you go are perhaps a bit too glib.
There are instances where driving across a speed bump or dip would rip apart the front lip and loosen a good part of the front fender as well.
It's a tough decision to make, but if your only issue is getting up and down your own personal driveway, I think you'll be ok without the lift as you can just buy replacement lips and get one of these ramp things.
Old 07-11-2016, 09:11 PM
farfromcommonGT3
farfromcommonGT3's Avatar
OP
The axle lift is in fact avail from Porsche as a kit your dealer can install. however, as with most anything factory done after the initial build it is $$$$$. It involves a LOT of work, coding the new ecu involved, and a lot of parts. Total for parts, at retail is 13k, labor just about 1500-2000 depending on your dealer's effective warranty labor rate. PM me and I can give you all the details you need if you want to get it done.
C
Old 07-12-2016, 04:44 AM
ezinternet
ezinternet's Avatar
Aftermarket info ... take a look at post #14 on this thread:
https://rennlist.com/forums/997-foru...-drivable.html
Old 07-12-2016, 11:00 AM
maximus136
maximus136's Avatar
wait for the right one to come along.....don't force things..don't chase the deal.....
typehxr1 (01-03-2022)
Old 07-12-2016, 11:09 AM
R.Deacon
R.Deacon's Avatar
Sean good advise from maximus
If the lift is must have for you
Wait for a Car equipped with it
Quick Reply: Axle lift install or aftermarket?
