GiroDisc PCCB rotor replacements for 991 GT3/GT3RS from CompetitionMotorsport.com
GiroDisc has completed testing and production of their PCCB replacement rotors and they are now available from CompetitionMotorsport.com.
Front (A1-154): 410mm x 36mm 26.3lbs
Rear (A2-154): 390mm x 32mm 22.9lbs
Both sets are a direct bolt on however the fronts will now require use of the pad shape used for the oem steel rotors (Pagid 4924 or PFC 7721.11.17.44 rather than Pagid 4927).
MSRP is $1,750 for both front and rear pairs.
Let us know if you have questions or if we can earn your brake business with a new set of rotors and/or brake pads.
What are the choices and cost of the pads for this application? Thinking about the swap to Iron rotors and is trying to gather some info before I order.
Thanks!
Gary
Thanks!
Gary
Because they use the same pad shape as the steel brake equipped cars, you have options from all the main manufacturers. Prices range from $450-650/set depending on your desired brand and compound. Feel free to ring us at 844.438.7244 to discuss your particular requirements and we will be sure to get you setup with the ideal pad.
