991 GT3, GT3RS, GT2RS and 911R 2012-2019
SmartyCam audio recording
Old 05-05-2016, 11:41 PM
Hermes911
Hermes911's Avatar
Default SmartyCam audio recording
I have been experimenting with recording audio of my 991GT3 exhaust with an external microphone connected to an AIM SmartyCam GP (bullet camera). Does anyone have a recommendation regarding microphone choice, microphone position, snaking microphone wire from cabin into license plate area, etc?
Old 05-06-2016, 12:27 AM
C.J. Ichiban
Platinum Dealership
C.J. Ichiban's Avatar
Received 1,952 Likes on 555 Posts
Someone on the GT4 forums a while ago did a whole breakdown. Was awesome
Old 05-06-2016, 10:14 AM
Nick Yoskin
Nick Yoskin's Avatar
Subscribed
Looking at those myself, can you post up a vid so we can see the quality?
Old 05-06-2016, 12:50 PM
meaker
meaker's Avatar
Rm21 probably can help you. He has his running into engine compartment.
Old 05-06-2016, 02:51 PM
MoeGt3
MoeGt3's Avatar
Subscribed
Old 05-06-2016, 03:47 PM
nlpamg
nlpamg's Avatar
Sub'd.
Old 05-06-2016, 04:23 PM
katmeho
katmeho's Avatar
I ran the SMC2 without a mic in my GT4 and it sounds horrible. I just bought the CAN extension cable that has the built in mic based on a number of recommendations.
V02566240 – CAN Bus + Integrated external microphone harness - L = 4 mt
http://www.aim-sportline.com/eng/pro...microphone.htm
Im also using these to cut down on the wind noise:
Amazon.com: Mini Fur Microphone Windscreen (Small): Musical Instruments Amazon.com: Mini Fur Microphone Windscreen (Small): Musical Instruments
Ill run the mic straight back to the trunk area in the GT4.
Sub'd...and will post video of my setup post May 18.
Old 05-06-2016, 10:52 PM
MarcD147
MarcD147's Avatar
I got good audio using external mic that I clip to the back. I am using it with my iPhone and route the cable next to my passenger chair out to the trunk. Check my YouTube channel for sound sample Flying DutchmanGT4
-20$
Audio-Technica's newscaster-style omnidirectional ATR3350iS lavalier microphone is engineered for intelligible, accurate voice reproduction. This high-quality condenser is ideal for video use, and is a favorite choice for aerobics/dance/sports instructors. Its low-profile design assures minimum visibility.
Old 05-07-2016, 03:26 AM
SanDiegoDavid
SanDiegoDavid's Avatar
I have the external microphone and microphone fur but the audio was absolutely horrible. Very disappointed in the Smarty Cam 2. Everything I tried, adjusting the input level, etc. didn't change the quality. For me its been a waste of $1,000.
Old 05-07-2016, 09:03 AM
fskof
fskof's Avatar
I was told by someone here to mount the microphone next to or behind the license plate. You will get no wind noise just exhaust noise. I have not tried it yet so don't know if it works
Old 05-07-2016, 03:07 PM
sccchiii
sccchiii's Avatar
Test video with lapel mic connected to GoPro with extension cord. I've since switched to smarty cam. Mic has mini fur on end and is simply wedged into partition seam in rear under back glass. Not perfect but decent for 2 min install.
Old 05-16-2016, 10:32 PM
Hermes911
Hermes911's Avatar
Thanks guys. I will test drive my new audio setup this weekend and will post the video on YouTube if it works. Either way I will list my setup and equipment.
Old 05-17-2016, 12:28 PM
C.J. Ichiban
Platinum Dealership
that sounds really good!
C.J. Ichiban
Platinum Dealership
my biggest beef with trying to do videos for track days is that with the windows down the only sounds we get are shshhhhshshwhhehhhhdhhshshssss
Old 05-17-2016, 01:19 PM
MaxLTV
MaxLTV's Avatar
Received 1,136 Likes on 559 Posts
This is how it sounds with Audio Technica lapel mic placed in the rear tow hook hole. The mic clips a bit and cuts off some bass (too much volume for it, and it's optimized for voice frequencies) so a better mic would give better sound there. It's easy to route the mic cable there completely inside - no exposed wires anywhere.
Quick Reply: SmartyCam audio recording
