Removing dial faces
#33
No I never did the sport chrono, to be perfectly honest I totally forgot about that, as the company who made them have the colours I may just order some.
Good spot.
Carl
Good spot.
Carl
#34
Had my first customer in today for a supply and fit job, he obviously went for the full set in yellow.
Car as it turned up-
Clocks out and stripped, standard codes in black do look pap.
Not too long after all the faces replaced and the unit rebuilt-
Back into the car, looks great straight away-
With the lights on-
Customer loved them and that's all that matters. I took the steering wheel off for a little bit more room and also because I bought an rs wheel for my car and he wanted one too.
They do look good.
Carl
With the lights on-
They do look good.
Carl
#36
Dial Colours
Hi, I'm new to Rennlist and am interested in changing the dials of my 991.2 to yellow. I note that the posts I've been reading were left in 2015 and wondered if I can still obtain info on how to obtain them?
#37
#38
Attachment 1215949
Attachment 1215950
Attachment 1215951
Attachment 1215952
With the lights on-
Attachment 1215953
They do look good.
Attachment 1215954
Carl
Attachment 1215949
Attachment 1215950
Attachment 1215951
Attachment 1215952
With the lights on-
Attachment 1215953
They do look good.
Attachment 1215954
Carl
thanks
#39
Mechanicalrepair, you're a brave soul & thank you for documenting the process with good pictures. My wife would be after me if I'd pulled the instrument cluster out of a new car!
I'll be undertaking the same process on my GT4, actually going to kph from US version MPH. I'm keeping the tach the same too & just doing the speedo dial. I'll send you a pm on that.
FVD Brombacher Germany makes the gauge dial covers in the custom colours, & that's where Suncoast gets them. FVD will do any of the customs sets, you can look at them on their website.
As you're now very aware, changing these gauge covers is a tricky finicky process. Another member did a DIY post a while ago. I talked with Rhonda from FVD USA who said that FVD will switch the dial covers for customers who send the gauges in.
These are the gt4 instructions:
https://rennlist.com/forums/gt4/9713...face-swap.html
#40
Superb - when I've done this on other cars there are two interior screws attached upwards on the inside of the binnacle to shroud, a bit tricky to find if never done prior.
Can you sell only the Tach dial in Red? for USA cars?
Ala Ferrari Scuderia! I too would like white dials with a red center Tach, great spec Sir
Now in the car and working perfectly
Attachment 1217147
To be honest if you have a little bit about you and are careful it really isn't a hard job to do, there is a lot of plastic that has to be removed etc so just got to take your time so not to break clips etc
Carl
Attachment 1217147
Carl
