40whp and 30wtq gains with Dundon Motorsports Headers, no flash required!
#106
Basic Sponsor
Dundon catted system v2 is in process. We're waiting for some parts to arrive here in the next week. While we're waiting getting some work done at the shop.
Steel workbenches under constructions at Dundon Motorsports Headquarters!
The tuning on the 997.2RS took longer than we expected due to travel delays and some technical issues with overwriting the ECU after previous tunes by other tuners, so we'll have to wait until next month or so for the 991 Stage 2 tune and testing of the catted system.
We expect to have the next version of the Dundon 991 Catted system with optimized based on what we learned last time in the next few weeks.
Lots going on right now with the catted GT3 setup, the GT4 getting home and opening the shop!
#107
Basic Sponsor
The catted setup makes power, about 30whp over stock, but I am not happy with the overall curve compared to the RH setup so I want to do some revisions and dyno again to compare before I build a final system. This way you get the best, not just the first thing produced.
Once the new shop is setup, things will go much faster
#108
Received 1,719 Likes
Ah, so you've adopted the Supersprint design utilizing the space vacated by side mufflers. Smart move. Have you tried stepped diameter tubing as a means to deal with the mid-range issue? Also, what are you getting for weight saving over stock system.
#109
Basic Sponsor
The Race header setup using the stock steel center muffler weighs about 1/2 of stock or a 43lb savings roughly, with a TI center its 11lbs lighter, so a 54lbs savings. I think thats correct, would have to confirm with Matt's thread.
The catted setup will weigh atleast 8-10lbs more just because of the cats. the problem is just trying to get everything to fit without altering the design of the headers too much, and killing power with the location of the cats. May have to do 2 more tests
#110
Regarding Supersprint design, perhaps adopted is the wrong word but not unreasonable when you compare the respective solutions. I don't know any other exhaust manufacturer other than you and Supersprint utilizing the space created by removal of the side mufflers.
#111
Basic Sponsor
Short answer, yes the headers have a stepped design, this is something Charles has used in his designs since the beginning!
We didn't copy SS, the only way for you to fit more length (like a cat) and keep the tuned length of the headers is to use all of the available space. That space happens to be up into the side muffler area. We are working to fit the cat in there and leave it straight with similar header length, this will help on the midrange power loss and the bit of drone from the v1 setup.
#113
Basic Sponsor
The cats will kill a few dB from our Race header kit and the rest is factory...
#114
You don't need an actual letter from Motul.
#115
I'd like to see a list with 300V on it.
#117
Basic Sponsor
Is that a yes?
Most, but not all, of my (our) headers are stepped. Most just once, some have 2 steps and some I build have none. Really depends on the testing done and involved and such.
Biggest issue is not cutting corners to save cost as most of the time that cuts performance.
#118
How much louder will it be? I've had side muffler deletes and even now (it may be broken) I can't tell a difference between exhaust button on or off except at idle.
In my experience the OEM Ti won't survive as it is and even less chance with side muffler delete, so I'd find a strong quiet center muffler.
I don't know enough about how it all works, so maybe I should come by for an education about no cat OEM tune options..
#119
Basic Sponsor
Have you done a test without cats?
We're working on a solution for the OEM Ti muffler, Charles has some sheet Ti that we can reinforce the back of the muffler if necessary. So far 911_RS has pushed his RS the most and no issues thus far.
the 997.2 RS with a Ti muffler it did have some issues after 2 full days on the track. We swapped it out with a Steel and are repairing it now...
