40whp and 30wtq gains with Dundon Motorsports Headers, no flash required!
#196
Basic Sponsor
Yes. I can do titanium as well. I would expect the cost to be 3x that of our current retail price after sourcing and or having the valves, flanges, vbands made and the bends purchased. Welding TI bumps the cost up a bit as well just from the process to weld it correctly.
#197
Curious, how much weigh does the set up save compared to the OEM set-up with the oem catted headers and side mufflers?
#198
#199
Received 1,721 Likes
I can make this setup from inconel if someone wants to pay the costs associated with it. Same as titanium. With 625 inconel I can go to 20-22ga and cut the weight of the tubes down by about 40%. The flap weight will not change nor will the flanges. I would suspect this would remove about 12-14lbs atleast from the weight of the exhaust, maybe a few more. We can also ceramic coat which I have thought about offering except break in procedure is specific and if not done correctly the coating will burn off.
How about Robert's question on bending vs welding of tubes?
#200
Basic Sponsor
The slip fit collectors I would leave because of heat expansion,
the secondary side pipes I can do the same but again it is several pieces of custom tooling per piece to get them done. on the side pipes it would only eliminate the one weld in the middle of the 3" pipes. the 2" and flex into the top of the center muffler would still be the same.
20ga TI would be slightly lighter than 20-22ga Inconel yes, I would expect the headers to go from weighing 10lbs each to about 4lbs each, and the secondary side pipes from about 6lbs to about 3. that makes it about 14lbs give or take. again I am just making estimates based on the material weight differences.
#203
Basic Sponsor
In my experience cracks generally happen from thermal expansion and vibration. .025-.035" wall inconel still retains a lot of strength if it is prepared and welded correctly. The product also must have been built correctly and installed correctly as to have no preloaded stress when all bolted down.
Titanium has roughly 2x the strength of aluminum but has the similar weight and can be very brittle and more often than not can crack from vibration combined with poor weld quality and contamination.
#207
Basic Sponsor
Buddy who has some skills for sure.
#209
Basic Sponsor
I would actually get TI bends to build my stuff instead of pie cuts. Pie cuts are A LOT cheaper for the material but there sure is a lot more welding.
#210
Oh yeah for sure, pie looks pretty for after turbo section but headers, never.
