991 GT3, GT3RS, GT2RS and 911R 2012-2019
40whp and 30wtq gains with Dundon Motorsports Headers, no flash required!
Old 04-19-2016, 01:57 PM
  #181
GT3 KSA
GT3 KSA's Avatar
Originally Posted by Robert Linton
Do you have a detailed picture of the system for the GT3 RS?
Only if you sign an NDA hahahhaah
Old 04-19-2016, 02:52 PM
  #182
Charles@dundonmotorsports
Basic Sponsor
Charles@dundonmotorsports's Avatar
I know there are not many pics out there, here are a few of a recently completed Dundon Motorsports Race Header system and Side connecting pipes with flaps
Old 04-20-2016, 02:14 PM
  #183
Earlierapex
Earlierapex's Avatar
Originally Posted by Jamie@dundonmotorsports
Earlierapex and Loungedog contacted, we'll send code readers to make it easier on you both to get the codes: they're on their way to is from Amazon as we speak
Thanks Jamie! Awesome service continues.
It occurred to me that it may not be fair to blame the smoke smell on the headers. On the first startup after my local dealer changed the headers (they ended up charging 6.5 hours), an exhaust/crankcase pressure valve (not sure which one or exactly how these work) blew up. It ended up dumping oil everywhere. The exhaust pressure valve (black, on top near intake) was a TSB recall item, so Porsche replaced it under warranty. Anyway, I've probably got some oil in various crevices that hasn't burned off yet.
Track day this Saturday should take care of that if it's the cause. I also changed the oil at the same time, so it could, alternatively, be a bit of overfill causing the extra puff on startup too.
Old 04-20-2016, 03:41 PM
  #184
GrantG
GrantG's Avatar
Received 4,701 Likes on 2,682 Posts
If you're running the cat-less race headers, that's probably an advantage to blow out that extra oil rather than soaking the cats...
Old 04-20-2016, 07:58 PM
  #185
TRAKCAR
TRAKCAR's Avatar
Received 1,583 Likes on 732 Posts
These headers are haunting me.
Reminds me I need to bring the car in to get exhaust valve fixed.
Starting to think its never worked right.
Old 04-20-2016, 08:04 PM
  #186
Basic Sponsor
Jamie@dundonmotorsports's Avatar
Looks like we'll have an RS tune in the next 3-4 weeks as well... A couple of cars lined up!
Old 04-20-2016, 08:06 PM
  #187
Macca
Macca's Avatar
With you on both sentiments! I think Im going to press the button on those headers next month. My exhaust valve tube departed some time after picking up the car in Europe and Im pretty sure it wasnt working for a long time. Its be reconnected and now is much more obvious when you push the button even at idle! Simple job...
Old 04-20-2016, 08:47 PM
  #188
Basic Sponsor
We're ready when you guys are!
Old 04-20-2016, 09:14 PM
  #189
911_RS
911_RS's Avatar
Can't wait for the dyno result!
Old 04-20-2016, 10:32 PM
  #190
Robert Linton
Robert Linton's Avatar
Are these connected into the stock final muffler? Can you make them in inconel coated so as to keep heat from burning paint? Can you get fully bent tubes so as to minimize the number of welds?
Old 04-20-2016, 11:10 PM
  #191
Alan C.
Alan C.'s Avatar
Robert, I think you might want ceramic coating.
Old 04-20-2016, 11:24 PM
  #192
Basic Sponsor
I can make this setup from inconel if someone wants to pay the costs associated with it. Same as titanium. With 625 inconel I can go to 20-22ga and cut the weight of the tubes down by about 40%. The flap weight will not change nor will the flanges. I would suspect this would remove about 12-14lbs atleast from the weight of the exhaust, maybe a few more. We can also ceramic coat which I have thought about offering except break in procedure is specific and if not done correctly the coating will burn off.
Old 04-20-2016, 11:33 PM
  #193
Robert Linton
Are the flanges machined?
Old 04-20-2016, 11:49 PM
  #194
Basic Sponsor
Current flanges are 321 and waterjet cut from plate and debuted.
When doing inconel I have cast and or machined flanges made that transition from the port oval to round to match the tube without having to anneal and form the tube. This adds a bit to the cost but in my opinion it is part of building inconel headers to perform and last for a long time.
Old 04-21-2016, 01:59 AM
  #195
911_RS
911_RS's Avatar
Wow you can make one in titanium??? Please let me know the cost
Quick Reply: 40whp and 30wtq gains with Dundon Motorsports Headers, no flash required!
