Brake fluid flash - do I need to worry about ABS?
I am doing first brake fluid change on GT3 - from factory fluid to Motul.
Do I need to worry about bleeding ABS pump in any ways?
I usually the following process:
- Remove the brake fluid from the brake fluid reservoir of the master cylinder using a syringe.
- Replenish new brake fluid.
- Build up pressure with the brake pedal or Motive bleeder.
- Perform flushing operation on rear axle brake bleeder valves - both valves of a caliper (Order: inside then outside and inside again )
- Perform flushing operation on front axle brake bleeder valves - both valves of a caliper (Order: inside then outside and inside again )
I flushed mine at 12 mo. and didn't bleed the ABS. Had there been any air introduced into the system I would have done the ABS.
