Are DFI engines unreliable?
#106
Originally Posted by jimmermd
Your illustration may be technically incorrect.
I believe that the injection sequence of DFI occurs when both sets of valves are closed, and the cylinder is under compression.
#107
Have 142K on my 2008 DFI engined Cayenne S. Had the HPFP changed twice (once under warranty) but besides that, the engine is still running strong. I did see carbon buildup on the intake ports when changing the vacuum pump (needed to remove intake manifold), but nothing different that other engines that recirculate oil fumes/blowby back into the intake.
#108
#109
I won't go back and read,but I believe I've stated this in the past : the solution is simple and many manufacturers are already implementing it. Have a second set of port injectors that spray when the computer demands it on the back of the valves. Or use a water injection system like the one on the M4 GTS,that cools the charge in the same time making more power.
#110
It's been some (many...) years since I did engine calibration myself but I would assume that the injectors can be open also during the intake stroke, to acheive full atomization/mixture during high load/high speeds. (where time is short in only doing it with closed valves)
#111
#113
#114
Any update here?
How is the 9A2 design?
same issue?
same issue?
#115
Not sure about .2 gt3 engine but in the newer 3.0 engines the fuel injector is back on top vs off to the side like the original DFIs. Dont know if that design kept the valves cleaner or not but we are basically back to hoping porsche has done the design work to keep build up from happening longer term. Good news is I haven't really heard of any 911s having carbon build up problems. Time will tell...
