Shavings
Received 5,413 Likes
Define "first oil change". 1,000 miles? 10,000 miles? Or somewhere in between?
Change at the 1,000 miles mark.
Change again every 5,000 miles.
Change yearly on low mileage cars.
Get a magnetic drain plug from L&N Engineering.
Run Mobil 5W50.
Run Mobil 5W50.
There shouldn't be any visible metal, period.
What's the diff in Mobile 5W50 and 1OW40?
They are not.
Good job on the early oil change.
Inspect your oil filter pleats. You should not see any visible metal shavings.
You could always pull an oil sample and send to Blackstone if you're into the UOA scene.
The GT3 has a metal canister filter so you can't check the paper filter for particles like you could on other Porsches.
Thanks for info. Seems I've read that Mobile OW40 was suggested. I want best protection possible at 9k
https://www.pegasusautoracing.com/pr...asp?RecID=3421
Just had dealer change my oil at 1000 miles. Was told no metal shavings observed and filled with Mobil 0W40. I'm located in Southern Nevada where temps can be in the 20's at night now and get up to 115 in the summer. Is 5W40 a better choice in this environment and if so do dealers stock this grade ?
