How do you turn the radio off?
I believe that your key has a memory setting that needs to be programed for your preference at start up. Mine is also programed to start AC even if it was off when I shut the ignition. It does this to allow driver preference based on Key #1 or Key # 2. Ask dealer
At least they let you set nav destinations while moving.
Same issue on cayenne.
Fix: set input to aux so you don't have blasting radio when you start car
I just returned from my dealer. My software is up to date and they tried installing it again. Did not work. It reboots about every 3 miles. I tried putting source to aux. Goes back to radio when it re boots. Needs a new unit. Nav does not work either, same with map.
