How to measure ride height
This will also work for the GT3..I measured my GT4 today using the factory procedure from their measurement points. The service manual spec is X73 F=116 mm +_10mm R 143Mm+_10mm so the GT4 should be 10mm lower.
Mine was 113.88&113.08F 135.74&133.28R ..i have a custom made ride height gauge that i developed for when i was setting up my lotus. Accurate to .2mm(.008) and repeatable.
With the 10mm the height drop from the X73. The factory spec for the GT4 ride height is( F 106 +_10 = 96-116MM) (R133+_10=123-143MM) with less than 5mm difference side to side.carl
4carl is offline Report Post Edit/Delete Message
