Grayish-white. You may not see it from your driver seat but I would bet if you stand at the back of the car at cold start up you will see some. When I took delivery of my car it had been sitting for a while. When I started it up there was so much smoke I thought the whole engine must be on fire. With the past GT3 engine issues it did give me a moments anxiety.
The dealer said it was also a result of the flat six set up of the engine as all of the oil cannot drain to the pan, some will remain in the chamber. Seems to make sense.
Hans, what dealer are you dealing with and where in Ontario are you from?
