I don't know if it comes that way stock from the factory on the GT4, but you can achieve it aftermarket. No one has the answer on PDK yet unfortunately.
It definitely does not disable the PTV.. PTV is an important part of the dynamics of the car... A better question would be if the rear wheel steering is disabled once the ESC is removed.
Same could be said of RWS. You also can't disable it
