NJMP Thunderbolt on 7/1,2
#31
Rob
#32
I just had a quick look at your video - it seems like you probably need to adjust your seating position to make 3 and 9 work. Speculating here as it was hard to see, but I'm assuming your arms are bent by more than 90 degrees when your hands are at 3 and 9? If that's the case, move the seat back a little or the wheel forward and make sure you get that angle right. Is your seat at in it's lowest position as well?
Practice on the street and try taking a few 90 degree right turns from stop signs/lights without taking your hands off the wheel from 3 and 9. It'll show you if you have the seating position dialed in.
#33
Location: Mid-Atlantic (on land, not in the middle of the ocean)
Received 3,750 Likes
