How does Porsche make an engine reliable at 9000 RPM????
#31
I feel confident the engineers have done the analysis and testing for 9000 rpm durability. Note the longer stroke RS is 200 rpm less. That said using 9000 rpm every shift for 100K miles might not work. I doubt any user does that and I never use full revs until oil is at least 150 and water 190. I want the viscosity to be appropriate and all hot clearances settled in. For example the Pistons warm much faster than the cylinders and I don't want to scuff anything.
My car has made blue smoke at start up twice. What I had noticed is that in both occasions I had pushed the car when the oil temps were in low 190s. I think this has to do with too much pressure at high rpms. Since then I have been paying attenation and if I am above 205F temps the oil pressure is lower at 9k rpm, but still encroaching the red zone. Of course this is a none-issue at the track where your temps are in 220s and 230s.
Thicker oils may be good for old school low rpm cars and race cars, but I think oil flow is key in high revving engines. I remember reading somewhere that F1 cars have to have oil that is almost water consistency to be able to provide adequate flow at rpms that they run.
#34
#36
A 911 motor with cylinders that size would only displace 1.8L. Just as a curiosity, the first famous Ferrari (166MM Barchetta) had a V12 with under 2.0L
#37
#39
And not sure about F-8 vs V8 which I hope we get to sample in a Porsche in the near future...
#41
Not certain how it compares vis-a-vis a flat-6, but Ferrari's use of flat plane crankshafts in its V8 engines, which have no counter balance weights, allow them to rev higher than typical cross plane V8s found in most American makes.
#42
To rephrase my question, Let's say my car is only driven on track (of course all service and warm up done) how many miles would it last before giving up?
In other words, how many track miles can the engine handle. 50,000 miles? 60,000 miles? 100,000 miles?
#43
If you average 85 mph then that makes 8,500 to 17,000 miles.
This is one of the reasons that extending the 4 years 50k mile warranty to track use is so generous (though very few people use their road cars exclusively on the track and do so that often).
#45
Racking up 15,000 miles at 10/10 on the track is not as easy as it sounds. That's 30 times the Indy 500 (and a bunch of those miles are under Yellow Flag)...
Driving at 8/10 on the road is not just a bit easier on the car - it's WAY easier and car will last much longer.
