Need (1) 991 GT3 wheel front in Platinum satin
$360 sounds more than reasonable for a try. How will they build up the missing metal? I'm not sure I'd want it welded.
I don't believe they will add any material back. Most likely just smooth it out by sanding and repaint. Now if there a chunk or a crack then they would weld. But I do not know the guy you are using process. I just know how vendors around my area would do the repair. I do know that if done right it will look just fine.
That's the process that has been performed on one of my wheels. $360 seems kind of steep but is worth it if the repair is top notch.
Hmm, for $360 I think I would just pay about 3x more and get a new wheel.
