Castrol Optimoly TA grease source?
Dealer does not stock, and $37/tube to order,
anyone suggest a more price-efficient source?
thx
thx
I guess my link didn't work try this https://www.motobins.co.uk/displayfi...search=1&go=GO
I have been buying from these guys since 2012.
Received 1,265 Likes
Don't buy too much. I apply it as directed for over a year now, and I barely made a dent in the small package I got from Suncoast. This way it's going to last me at least another 10 years.
Do you 'break' the whl nut apart to grease?
Have you found a way to apply the grease without making a mess?
I always have a problem getting the retaining ring back in!
any instructions w/b appreciated,
thx,
P
a) A very high or very low torque is required to loosen the wheel bolt (more than 518 ft/lbs or less than 296 ft/lbs)
b) In the event of a jerking, fluctuating torque when tightening
c) If you feel any stiffness or slip-stick effect when turning the cone ring inside the central bolt back and forth with your hand.(Apply pressure when doing this test).
Also, email sent.....
^ thanks Mike!
I have been been messing with these CL nuts since 2011, and I hoped there was a more efficient procedure to lube and get the lock washer back in.
Any advice much appreciated!
P
P
