Originally Posted by rosenbergendo
(Post 12332067)
Lift on both 997 and 991 has been such a disaster!
Software Upgrade
Originally Posted by Just in time
(Post 12332358)
My lift works fine. No sounds/noises whatsoever.
Originally Posted by jlanka
(Post 12331536)
fixed
Originally Posted by mainly
(Post 12330575)
ahhh. is that what that is?
glad to see someone else has had it... for me it sounds like a creaking/scraping noise...usually when backing up with the wheel almost cranked. so is it serious? should i have them look at it? vehicle is already going in at the end of the week for rattles from the rear.
(Post 12330862)
The "driving over acorns when the wheel is turned hard at slow speeds" feature is well documented and nothing to worry about. Search on rennlist and you'll find numerous posts about it.
(Post 12332358)
Originally Posted by Mike in CA
(Post 12330121)
I keep butting in on Rob on this subject (I did it in the original thread too) but this will save him searching for it....
https://rennlist.com/forums/991-gt3/...like-this.html |
Not sure about the software upgrade but there is a service bulletin for checking some bolts/nuts based on FAL and VIN number. Car is ok to drive. Have my appt June 17. Should take 1-11/2 hrs according to service mgr.
I am using my lift more than twice every time I drive the car. Impossible to live without lift for me.
(Post 12330121)
I use my lift every time I drive the car and have had 0 issues. It works great for me.
Mine failed miserably and took over a month to fix about a month after I took delivery. After that, (part delays, ETC.) it has worked GREAT.
So what is this software upgrade about?
I called the dealer today and he said that although the letter referred to a software upgrade, in fact, it is a standard letter and there is no software upgrade - just some work to be done tightening and checking the torque on the upper strut bolts and the lift mechanism. Will take 1.5 hours. Is booked for next Friday so if I get more details I will let everyone know.
Agree with ^. Mine is booked for June 16th. I have no issues with my lift which I use several times daily.
Not a software issue. My tech. at Suncoast this AM showed me the nuts on the hydraulic lines to the lift struts and said they needed to be tightened. That was the reason for the notification.
My noise was the air line vibrating against the body, all fixed up
