How-to: building a GPS-based PSE valve controller for passing track sound checks
#46
I was gonna do that this weekend
#47
Finally finished... now I actually have to verify the solenoid config and figure out how to remove the cayman engine cover
#48
All done. Cayman GTS wired up just like GT3. Now if there is a Laguna Seca track date around the corner... He he!
http://www.planet-9.com/981-cayman-b...ound-mrls.html
#49
#51
Well... I built a bunch (4) for a few friends locally. Wow... it took a lot of time and patience. Now I know why Mech33 isn't willing to build anymore. I don't think I will neither. I had some bad luck on the way like amazon sending me the wrong board and such.
I will say for anyone trying this make sure you get a crimper...
It will make your life so much easier so you don't have to solder every connection which is very time consuming
#52
Wow you're really cranking those things out! Nicely done for your friends. I made 3 total and that was enough...
Amazon.com: GM Delphi Weatherpack Crimper Tool: Automotive
#53
Received 1,149 Likes
Just ordered the parts. Will be an evening project for the week my family is away. Thanks a ton for detailed instructions. By the way, any leads on extra-cheap turn-away pipe to get the sound all the way under 90dB?
#54
Joe - did you run yours through the firewall?
#58
Not yet, but I know how to. There is an easy access point just under a plastic trip at the level of the arms for the lid hinge. I can take pics next weekend. You access on the inside by pulling the trim just adjacent to the bottom edge of the rear window
