991 GT3, GT3RS, GT2RS and 911R 2012-2019
How-to: building a GPS-based PSE valve controller for passing track sound checks
Old 05-29-2015, 11:45 AM
SmokinGTS
SmokinGTS's Avatar
Brilliant, just Brilliant...
Old 05-29-2015, 11:59 AM
mooty
GT3 player par excellence
mooty's Avatar
Received 5,482 Likes on 2,269 Posts
wow, impressed.
really cool!!!
now i can program my gun turret and take out that sound booth.
Old 05-29-2015, 12:20 PM
Mech33
Mech33's Avatar
Originally Posted by Bartron
Incredible!!!! My nerd brain just exploded.
This may be obvious but, is the solenoid default to allow vacuum to the flaps? I'm looking to delete the valves all together and wonder if the best way would be to do it at the solenoid by capping/unplugging.
The solenoid unpowered state puts atmospheric pressure to the exhaust valves, leaving them open and the exhaust "loud". You have to actively apply 12V to switch it to vacuum to hold the valves closed. At idle with PSE button off, the stock system applies 12V to the solenoid to keep it quiet.
If you simply leave your harness disconnected and open like Joe mentioned, then the valves will stay open all the time (similar to unplugging the vacuum lines from the valves).
Old 05-29-2015, 12:37 PM
Alan C.
Alan C.'s Avatar
So you could route the jumper wires to the cabin and add a switch to manually override valves? Sounds reasonable.
Thanks for posting your work. Very well thought out solution for those subjected to sound limitations at their tracks. Which, most likely, will be all of us sooner or later.
Old 05-29-2015, 01:36 PM
Serge944
Serge944's Avatar
Bravo. Thread of the year!
Old 05-29-2015, 02:42 PM
rockitman
rockitman's Avatar
Wow, what a brainiac. Impressive is an understatement ...
Old 05-29-2015, 05:05 PM
nlpamg
nlpamg's Avatar
****ing brilliant! great job, man!
Old 05-29-2015, 05:07 PM
nlpamg
nlpamg's Avatar
btw, you need to make and sell these things!
Old 05-29-2015, 06:08 PM
rockitman
rockitman's Avatar
+1
Old 05-29-2015, 06:25 PM
Mech33
Mech33's Avatar
Thanks everyone for the kind words!
Not worth the trouble, unfortunately. But maybe some other enterprising individual will do so!
Old 05-29-2015, 06:27 PM
Mech33
Mech33's Avatar
Yes, you can route those lines into the cabin and hook them up to a manual switch. If all you want is loud vs. stock, then a simple SPST switch is all that is needed to either make or break the connection between the 2 wires.
If you want quiet vs. stock, then you need a +12V source and at least a SPDT switch.
Old 05-29-2015, 08:40 PM
stronbl
stronbl's Avatar
Piling on with the compliments here, but worth it ... outstanding, simply outstanding what a great bit of info, tech and "how to" as well !! Thanks Mech33.
Old 05-29-2015, 09:20 PM
doborder
doborder's Avatar
I got the parts... lets see if I can actually follow directions. I bought some extras so I will make a few more if mine works!!!
Old 05-29-2015, 10:07 PM
MaxLTV
MaxLTV's Avatar
Received 1,149 Likes on 567 Posts
Awesome! Thanks for doing that. I'll try to get it assembled soon.
Old 05-29-2015, 11:37 PM
allans
allans's Avatar
What an AWSOM REPORT! I can't imagine the work it took to put this together but, I think I'll just try to "wire" the flaps closed. Can you please comment on how to accomplish this procedure. Many Thanks, Allan
Quick Reply: How-to: building a GPS-based PSE valve controller for passing track sound checks
