991 GT3, GT3RS, GT2RS and 911R 2012-2019
How-to: building a GPS-based PSE valve controller for passing track sound checks
Old 10-01-2019, 04:57 PM
  #211
hwashcraft
hwashcraft's Avatar
Thank you for this article. For some reason, the photographs you included to show wiring details are no longer with the post. Are they available or do you have a schematic so I can be sure I have wired this correctly? Thanks.
Old 10-07-2019, 03:05 PM
  #212
hwashcraft
hwashcraft's Avatar
I have installed all of the wiring for the Mech33 solution (4 wire) and have put the controller together (need to program and test) but would prefer a smaller, more convenient package. What is the status of your project? BTW, as an ex-amateur radio operator, I have done a lot of electronics building. If you only have a PCB and parts list, I can handle soldering surface mount (except the really tiny ones...). Status?
Old 10-07-2019, 03:14 PM
  #213
Crazy Eddie
Crazy Eddie's Avatar
Honestly ..... I think the track nanny is really the best solution
it will cost more for sure ... the expression “you get what you pay “ for really applies here ....
my two cents 😉
good luck
Best regards
Ed
Old 10-07-2019, 05:52 PM
  #214
hwashcraft
hwashcraft's Avatar
Adding to the installation notes, a few observations, recommendations.
Old 10-07-2019, 06:07 PM
  #215
hwashcraft
hwashcraft's Avatar
Status of the track nanny project. I have put in the wiring to run from the ecm and the solenoid (4 wire configuration) to connect to the Mech33 controller I built, but would like a more compact set up. If you only have parts (even smd), I can construct. I have worked with surface mount on amateur radio equipment I have built.
hwashcraft
Quick Reply: How-to: building a GPS-based PSE valve controller for passing track sound checks
