Coolant Temperature
Coolant Temperature
Warning went off yesterday.
I love my dealership. Jon and Scott at Rusnak are taking care of it, returning my tire pressure to stock (it was bumped up a bit more after a track day) and checking out some funny noises. Best of all, nice chance to drive a loaner Cayenne and I'm very impressed by the big car.
On reboot, it was still off, fan was on probably because it couldn't tell if it was too hot or not.
Dan (posts first warranty issue and will advise as to the outcome)
Heh, thanks my first effort was at 80. Note the warning light was flashing too.
At least this time I didn't have Kelly Clarkson on at the time for my embarassment and everyone's viewing pleasure.
No warnings on mine but temps would rise when stuck in traffic. On second visit to address problem, the thermostat was removed, tested and found not to open properly at the requisite 81C temp. It's pictured below after being replaced. Fingers crossed that the problem's fixed.
Warning went off yesterday. I love my dealership. Jon and Scott at Rusnak are taking care of it, returning my tire pressure to stock (it was bumped up a bit more after a track day) and checking out some funny noises. Best of all, nice chance to drive a loaner Cayenne and I'm very impressed by the big car. On reboot, it was still off, fan was on probably because it couldn't tell if it was too hot or not. Dan (posts first warranty issue and will advise as to the outcome)
Just a point to note that the Over heating issue is quite different than the issue raised by the OP. The overheat issue is caused by the thermostat shut closed and can be detrimental to the health of the engine. I've had this one too and it's a thermostat replacement under warranty. The other issue is the thermostat open before the target temp has been reached...
I keep spare oil in the car, and now I guess a few bottles of water hell who needs a fire extingusher. The other two are more important
Just a thought here : I wonder if the factory didn't fill the coolant system or they don't have time do do a proper bleeding procedure. My guess it's the latter and as the owner drives the car,the air slowly purges out of the cooling system and the coolant level drops tripping the emergency light.
