I see the extended rocker's line... way more protection than the standard shark fins. I think this is the way to go.
Note that my Xpel install was done by Derek at Atlanta Protective Films. He does not use the standard Xpel extended rocker template, he uses a custom reduced full side panel that covers even more than the extended rocker template. You can see the line on mine if you look. It runs up to the window trim just rearward of the door opening.
