Make sure you plug the unplugged lines of you leave them disconnected if you don't want a vacuum leak.
Can I ask what are the implications if this is not properly done?
I followed the earlier advice and attached two pieces of screws to each end, but I am not sure how secure they will be. I didn't use the set screw as I imagine it will be difficult to remove them.
