991 GT3, GT3RS, GT2RS and 911R 2012-2019
Oil consumption at Track
Old 05-05-2015, 11:21 AM
Rob in Potomac
Rob in Potomac's Avatar
Default Oil consumption at Track
Anyone experiencing significant oil consumption at the track - much more than daily driving?
I have to add a quart after about 3 sessions (60 - 75 minutes).
Old 05-05-2015, 11:28 AM
zedcat
zedcat's Avatar
Think it's been covered in some other threads but yes that sounds about normal. Last Friday I added about 600ml after a total of about 100 min but not driving hard for the first 30min or so.
Old 05-05-2015, 12:01 PM
Road Racin
Road Racin's Avatar
Yes. Not sure what I started with but had to add twice... Back to normal since the track day..
Old 05-05-2015, 01:31 PM
Mech33
Mech33's Avatar
I did (4) 30-minute sessions at Laguna and didn't have to add any oil. I forgot to check it before and after, though, unfortunately. At Thunderhill this weekend I'll get some readings at the beginning and end of each day.
Old 05-05-2015, 01:48 PM
JasonAndreas
Technical Guru
JasonAndreas's Avatar
How close are you running to full? Remember it's a dry sump... Try keeping things on the lower side and see if you're still going through oil?
Old 05-05-2015, 02:05 PM
Rob in Potomac
Never fill above 2nd level on indicator and couple of times had red light come on indicating immediate fill required,
Old 05-05-2015, 08:13 PM
mqandil
mqandil's Avatar
This is a bit above average but certainly in normal range and especially if you don't have many miles on the car. It gets much better after 5000 miles. I am slightly above 10,000 miles and I have noticed that the oil consumption on both track and steert has gone down considerably. How many miles do you have on your car?
Old 05-05-2015, 08:51 PM
_BrakeDust_
_BrakeDust_'s Avatar
Mine used 200ml over a 3 day event. 4 sessions per day. 25 minutes each.
Old 05-06-2015, 01:09 AM
CALSE
CALSE's Avatar
Mine drinks a quart after every 125 track miles.
Old 05-06-2015, 01:39 AM
Alan C.
Alan C.'s Avatar
Four sessions at Mid-Ohio with MOR two weekends ago and didn't use any oil. I had a set of MPSS on and didn't really push the car that hard. The MPSS heated up in about 8 laps.
Old 05-06-2015, 11:09 AM
malmasri
malmasri's Avatar
The car will consume oil until the valves are seated well , approx 1500 mi.
then it will need 1/4 QT about every average DE day running hard. You should keep the oil level in the middle of the green bar, not more than that, and check daily at the track.
Old 05-06-2015, 03:52 PM
bruce987
bruce987's Avatar
Yes my '15 uses about a 1/4 quart after a weekend use at the track.
Old 05-06-2015, 04:10 PM
Rob in Potomac
About 4000 miles.
Old 05-07-2015, 01:08 AM
mqandil
mqandil's Avatar
About 4000 miles.
It should get much better once you add couple of thousands miles. I would not worry much about your current oil consumption. Mark
Old 05-07-2015, 05:34 PM
quickshift
quickshift's Avatar
Concur with 1/4 qt after 5 - 30 min. sessions running moderately hard. Car has 5800 total miles.
Quick Reply: Oil consumption at Track
