Blackmill Performance Anti-Wind Buffeting Kit - Fits all 991 and 981 vehicles.
#31
Basic Sponsor
Quoted from the owner of Blackmill
"The tab width is short as possible by design to be effective at all speeds within cars performance spec, i.e. max speed. Shorter versions were tested and failed at speeds over 135.
The shorter tab solves the problem at highway mode (75-80) only. I noticed some forum posts that have talked about my kits looking ugly, cheap plastic look, old cost, etc.
The blackmill parts are 100% effective for eliminating wind buffeting effects at all speeds intentionally. Functional art. This is not an area where I'd want some flashy piece with improper surface design, and not fully tested to 150+ in all conditions.
Simple, subtle and functional was the design goal, and we nailed it. I personally love the look of the new parts and get props all the time.
Hope this helps."
Eric
Hope this helps."
Eric
Porsche Performance Specialist
John@Fabspeed.com
215-618-9796
Fabspeed Motorsport USA
155 Commerce Drive Fort Washington, PA 19034
www.Fabspeed.com
John@Fabspeed.com
215-618-9796
www.Fabspeed.com
#32
the car in 15 minutes. Used 3M double stick moulding tape and they have
weathered the elements and no adhesion issues. Plus they only stick out about
a half an inch.
#33
Don't get me wrong. Mech33's looks fantastic in comparison to the elephant ears (hfm that pic is perfect) and I'll probably do the same thing. $130 is absurd for a piece of bent aluminum and some double sided tape. At least AWE's is carbon fiber and a "replacement" part.
What boggles my mind is how in the world did this pass Porsche's quality control and was never fixed. IIRC all models are affected by this. I wonder if the .2 will have this issue as well.
#34
Basic Sponsor
At the end of the day, you guys have plenty of options. I posted what the owner of Blackmill stated was the reasoning on why they can't be shorter.
#35
#36
Many of our competitions offerings are shorter by mistake in my opinion, some online videos even prove that shorter designs don't work at high speeds. Don't fall for "white nose" disclaimers.
The shorter tab solves the problem at highway mode (75-80) only. I would be very disappointed with competitor products on track. I noticed some forum posts that have talked crap on my kits looking ugly, cheap plastic look, old cost, etc.
The blackmill parts are 100% effective for eliminating wind buffeting effects at all speeds intentionally. Functional art. This is not an area where I'd want some flashy piece with amateur surface design, and improperly tested to 150+.
Hope this helps."
Eric
Hope this helps."
Eric
#37
I simply use a small flat piece of plastic from my battery tender packaging. Just cut it with scissors, 2 in x 5in long. When at track, open door, hold in place, shut door. Works great!!!! When done, throw them in the glove box
#38
Thanks for the comments / opinion. Perhaps the Blackmill version has to be so large because the "airfoil" is at the trailing edge of the plastic triangle where it meets the window cavity? That's definitely a different boundary condition for the foil. My $20 rubber wiper version that mounts at the leading edge has been tested up to ~120 mph at Laguna Seca with zero buffeting issues so far. I'll test it up to 140 mph in about 2 weeks at Thunderhill. Fingers crossed.
Do you have any more pics or description you can post of what you used?
It looks nicer than the $140 piece of bent aluminum with VHB tape on it too!
#39
Here it is:
I decide to try Mech33's idea! Great idea and very inexpensive! All you need is the wiper blade,
scissors, Double sided tape with foam center, and some rubbing alcohol to clean the surface.
I took it out for a 110 mph trial with only the driver window down and NO BUFFET!
Thanks Mech33! If anyone would like a step by step guide I'll post it.
Total cost: about $20
Here's the link to the blade:
Amazon.com: Trico 25-190 Force High Performance Beam Blade - 19": Automotive
#41
#42
You only need one. There's enough to make two.
One thing I like about this wiper fix is you can take it off and put it back on anytime you want to. I now have the Blackmill product, Although the Blackmill product is less ghetto IMO, i do have some regret in not being able to easily take it off or on.
