6pt harness lapbelt connected to OEM seat belt buckle?
I'm planning the installation of my 6pt harness into a LWB car. On the tunnel or inboard side of the seats the OEM seat belt buckle makes routing the 3" lap belt through the opening in the seat a little challenging.
Does it make sense to consider using the existing OEM buckle the mounting point for the 3" lap belt? IOW, remove the 3" belt's snap on buckle and replace it with an OEM male buckle or tongue and snap it into the OEM receiver? The photo may make this clearer.
A setup like this would be simple and convenient. I'm reviewing it with the tech guys at the events I participate in, but I would like feedback here too.
The 6pt snap on buckle is not sewn in, so it would be easy to replace with an OEM compatible buckle or tongue.
The 6pt snap on buckle will fit through the existing opening in the seat, but it is tight because the OEM buckle is pretty rigid and you can't move it out of the opening (at least I haven't been able to).
Comparing the quality of the OEM tongue to the snap on buckle, they are 3mm and 4mm thick, respectively. However, there are other metal buckles that fit into the camlock that are also 3mm thick, so this doesn't appear any less robust than other parts of the harness.
The original belts (Europe) are fitted with the correct anchor point not like the one in the picture. Unfortunately I am not a home right now to photograph our set up which is really simple to install. The fitment that secures the belt to the floor (tunnel) area is set up to receive the correct bolt and spacer arrangement.
Routing the belt through the seat opening alongside the existing seat belt anchor is no issue.
Maybe the US set up is different. I will be fitting my passenger side 6 points when I return I might take some photos of our set up.
