991 GT3, GT3RS, GT2RS and 911R 2012-2019
New PCCB and Track days – Facts Feedback Thread
Old 04-11-2015, 06:45 PM
SanDiegoDavid
SanDiegoDavid's Avatar
Originally Posted by PierreTT
David,
Please report back after your 3 days at COTA
Thx for your input!
I will. Just some more information regarding the measurements of the wear after 9 full track days and one AutoX. I have included the picture of the data sheet showing how little my rotors are worn versus new.
The first column: New rotors.
Second column: Absolute minimum wear limit
Third column: My measurements.
Fourth column: Recommended minimum limit (a buffer of 5)
I decided to have all 4 pads replaced. They had plenty of thickness but they displayed pitting and cracking that most likely would have been OK but I want absolutely will be OK!
I just dropped my car off at GMG for the Gen 1 cage, Sparco Evo II seats, Schroth 6 points/Hans compatible, the center bypass and their track suspension set up. Looking forward to the "new" car before COTA. Shout out to Allen at GMG, great guy.
Old 04-11-2015, 09:06 PM
allans
allans's Avatar
^^^ Thanks for this. Allan
Old 04-12-2015, 08:20 AM
PierreTT
PierreTT's Avatar
^^^ +1
Old 04-12-2015, 10:08 AM
TRAKCAR
TRAKCAR's Avatar
Received 1,586 Likes on 734 Posts
Why do the numbers represent? Weight in kg?
Why the 3 rows?
Why is there such a variance between the 2 front rotors and the 2 rear rotors when new ( 1st columns)?
Old 04-12-2015, 12:12 PM
bigkraig
bigkraig's Avatar
I plugged those values into a google doc and added percentages to the amount used.
https://docs.google.com/spreadsheets...it?usp=sharing
Any idea how the wear limit is calculated? it seems to fluctuate a few points on all rotors.
Old 04-12-2015, 01:38 PM
nova996
nova996's Avatar
It seems to be slightly over 75% of the starting value at that point.
Old 04-13-2015, 12:52 AM
SanDiegoDavid
Sorry guys, I don't have answers to these questions. My GT3 tech and SA were out when I picked the car up so I didn't have anyone to ask all the same questions. I'll see if I can get some specific answers to these questions. Needless to say it looks like 30-40 track days out of a set of PCCB rotors.
Old 04-13-2015, 09:49 AM
W8MM
W8MM's Avatar
What's different between the PCCB rotors fitted to the 918 and those on the incoming 991 GT3 RS? They appear to be the same size. Are they the same parts?
The reason I ask is that I had a long talk with David Donohue when he let me drive a PCNA 918 last fall. I quizzed him extensively on 918 PCCB rotor durability since my Carrera GT PCCB rotor life had been so disappointing. He told me that of the 7,000+ miles on the odometer, at least 4,000 miles had been on the track with the brakes being seriously abused. PCNA later confirmed that the car was wearing its original rotors and that they saw no reason to replace them now or in the future.
This situation is vastly improved over the Carrera GT. I am running MovIt replacement rotors (Surface Transforms) on the CGT to improve the track-day running costs with no difference in performance. If the 991 GT3 RS has the same PCCB rotor parts as the 918, it should work out pretty well for track driving.
Anybody know?
Old 04-13-2015, 10:25 AM
bigkraig
bigkraig's Avatar
991 GT3 had the same PCCBs as the 918 so I assume the RS will be the same
Old 04-13-2015, 07:15 PM
TrackDays247.com
Former Vendor
TrackDays247.com's Avatar
PCCB on current Porsches are soooo much better than gen 1 & 2...such a difference.
Removing PCC for extended track usage isn't as much of a consideration as the old days!
Using Pagid RSC1 pads + Motul 600 or SRF = once heck of a track setup fro brakes on these cars.
Old 04-13-2015, 07:37 PM
nova996
nova996's Avatar
Yeah, this thread has been helpful. I'll go with the RSC1 on new PCCB's for 5 and then 10 days and report back on this thread.
I don't have as much time for the track as I once did, so it may take me a while. but hopefully we can compare that data to the wear on OE pads.
This will be on a GT4, though, which doesn't enter turns as hot of course. But maybe we'll get more GT4 data soon.
Old 04-14-2015, 02:25 PM
race7117
race7117's Avatar
I did 2 track days at a former NASCAR short oval turned into a road course. Meaning heavy tire wear, really only 1 heavy braking zone. Checked at Dealership service and minimal to moderate wear after a total of 5 track days total. I am not really confident in their measurements, I did not see a form like the one David has. Anyone know of a decent home remedy for measurement? I'm going in to see the service guys this week and hope to find some kind of measure without buying a expense "porsche exclusive" tool. will see what I find
Old 04-14-2015, 03:54 PM
DeerHunter
DeerHunter's Avatar
AFAIK, you can weigh the rotor. They don't wear in the traditional way, but get lighter. The minimum weight is imprinted on the hat, I believe.
Old 04-27-2015, 08:13 AM
RacingBrake
Former Vendor
RacingBrake's Avatar
Yes, here is a weight table for Corvette ZR1 (C6 & C7), and Ferrari F458 that was presented in FChat here:
http://www.ferrarichat.com/forum/143876195-post30.html
More detail weight allowance and comparison on ZR1 CCM rotors (Front and rear) are posted in RacingBrake forum here:
How to determine when to replace CCM rotor ring
As you can see from the table if F458/F430 front rotor if replaced with ZR1 you save approx 0.4 lbs of rotor weight.
How much is 100 grams (3.5 oz) weight to loss?. It's about 2.5 sets (10 sets per rotor) of these hardware.
Old 04-27-2015, 10:41 AM
TRAKCAR
TRAKCAR's Avatar
Do I interpret is correct, are the front rotors of the C7 Z06 the same as the front and rear rotors on the F458?
Do you have this table for the PCCB?
Thanks for posting
Quick Reply: New PCCB and Track days – Facts Feedback Thread
