PDK Observations
#31
To each his own.
#33
The auto program does learn your driving style and will continue to relearn as you change it. I also find auto useful in controlling RPMs. I am attempting to hold the RPMs below 4200 the first 2000 miles - I know there are varying opinions about it on this forum for need of break-in time or not. However the car is so suductive it is hard!! Auto helps...
#34
In AUTO (with no buttons chosen), the PDK-S will kick down, dependent upon how far down you have depressed the gas pedal. I have had it skip from 7-4 when flooring it.
#35
Now what I am not sure is if the PDK really goes to neutral, or disengages both clutches when you pull both paddles. The gear number flashes, but doesn't show a "N" so I wonder and if it only disengages both clutches, then part of my genius strategy may be pointless.
I don't think it makes a whole hell of a lot of difference, but if you want a smoother feel when stopping gently (e.g. so the expert in the right seat won't remark how clunky the car is), pulling both paddles all the way until stopped works for me.
#38
I find the shifter a silly appendage that makes no sense compared to paddles that can be accessed with hands on the wheel. I'd rather have 3 simple buttons like on my McLaren - D, N, R. I'd rather have unobstructed view of the center console buttons. I don't know any other DCT-equipped car with a shifter, but it sounds like a lot of folks want to take hand off wheel to shift - baffles me, but whatever is fun, go for it.
#39
I find both modes helpful. The manual mode is easier than I anticipated as it seems more intuitive than most cars with a clutchless paddle shift, you just don't move your left foot. I do down shift in manual, probably more for the fun of it. I mostly use auto in town and traffic. I don't have any smoothness issues on auto shift with a light, medium or heavy throttle. I think just being very progressive with your right foot is the key.
#41
Since at a stop you're in 1st gear, IIRC when you pull the paddles the gear indicator "1" will flash in the display and the clutch will remain disengaged until you release the paddles, just as if you were in 1st with the clutch depressed in a MT car. The indicator doesn't show "N" so I don't think you are actually in Neutral.
#42
So if I am in manual mode and approach a red light in second gear and simply stop, the car shifts from second to first on its own to not stall. This is a smoother shift than if I did it myself yet no paddles are pulled.
What is happening in this lazy scenario? Is there anything wrong with it?
#43
the problem is i dont think 4th is low enough (for max acceleration)
because when im in pdk sport and auto, as we know ist always in the lowest gear so when you floor it your not in low enough gear so it bogs a bit. it should go to 3rd, or even 2nd, as there seems to be lots of revs left on the tach...
im pretty sure on this, so it seems they tuned pdk s to be more for track where theres always turns coming, than flat out speed?
either way i wish it kicked down at least 1 more gear when in pdk sport.
#44
That said, I think the jerkiness that some people object to isn't so much in the 2nd to 1st downshift that you describe, but rather when the clutch finally and automatically disengages from 1st as you come to a stop. By pulling the paddles, you can disengage the clutch earlier and coast to a smoother stop without that final "clunk". Sometimes I pull the paddles and sometimes I don't. Nothing wrong with either method.
#45
Nothing at all, IMO.
i have alwasy found this 2nd to 1st shift when slowing to a stop to be clunky. with my cls63, my f10 m5, my e60 m5 and now even with the gt3... and they all have different transmissions, (except for the f10 and gt3 - both DCT's)
have always wondered what it was caused by...
