991 GT3, GT3RS, GT2RS and 911R 2012-2019
exhaust / bypass - which one to choose?
Old 03-27-2015, 01:29 PM
  #46
Jimmy-D
Jimmy-D's Avatar
Received 1,389 Likes on 720 Posts
What does any one know about the Bypass Pipe Set by Cargraphic? Does this just Bypass OEM Side mufflers but maintains the OEM rear? Does the PSE button still function? How does it sound?
Old 03-27-2015, 02:24 PM
  #47
odwa
odwa's Avatar
Their site states center muffler is stock Porsche and Bypass keeps PSE button. I want to keep center stock muffler to not compromise any possible aero benefits
Old 03-27-2015, 02:30 PM
  #48
kosmo
kosmo's Avatar
when did the topic of compromised aero of removing center muffler get going?
Old 03-27-2015, 02:32 PM
  #49
ipse dixit
ipse dixit's Avatar
Received 10,784 Likes on 4,775 Posts
https://rennlist.com/forums/991-gt3/...s-systems.html
Old 03-27-2015, 02:39 PM
  #50
Scott997
Former Vendor
Scott997's Avatar
I had the shark werks center muffler bypass on my 997.2 and LOVED it. Naturally I went with the same choice on my 991. I also have my valve bypassed.
Sounds Excellent at WOT and docile at cruise. Highly recommended.
Old 03-27-2015, 03:32 PM
  #51
bigkraig
bigkraig's Avatar
Originally Posted by NateOZ
Akra is making the same claim of 20 hp on their Evolution Race setup, but it occurs at 3,950 RPM and 11 hp increase in peak hp at 8,000. I'm assuming there is some inefficiency in the stock setup that they both correct + the valves being gone.
I don't know exactly when stock valves open, but I thought it was 4,000? It seems to make some sense that the biggest delta without the valves is right before they would normally open.
This is what Betim at BBi was telling me, with the valves there is a dip in power in the stock GT3 configuration. One of the benefits of their side muffler delete & valve removal is the removal of that dip.
Old 03-27-2015, 04:40 PM
  #52
MoeGt3
MoeGt3's Avatar
I wish there were better videos of the Cargraphic setup. Does anyone have anything interesting to share? Other than the ones on the website..
Old 03-27-2015, 05:01 PM
  #53
aznkuja328
aznkuja328's Avatar
what kind of video do you need? I currently have their rear muffler bypass and will soon receive the side muffler bypass with valves that works with the PSE button.
Old 03-27-2015, 05:05 PM
  #54
Jimmy-D
Jimmy-D's Avatar
So will you be reinstalling the OEM rear muffler with their side deletes- I am trying to figure this out?
Old 03-27-2015, 05:06 PM
  #55
MoeGt3
MoeGt3's Avatar
A video similar to this would not be bad at all
Old 03-27-2015, 05:13 PM
  #56
aznkuja328
aznkuja328's Avatar
I know what they are, they have valves like oem, and they work with the pse button. they can be used in conjunction with oem rear muffler. when the valves are closed the exhaust is routed to the upper section of the rear muffler and thus the sound is muffled. they work as bypass when the valves are opened that route the exhaust to the lower section of the rear muffler, so it will work like the bbi when the valves are opened. I believe they will sound like the bbi when the valves are opened because oem headers and oem rear mufflers are still in place.
  #57
aznkuja328
aznkuja328's Avatar
yes jimmy. they will arrive in April. I want the oem rear muffler.
Old 03-27-2015, 05:14 PM
  #58
aznkuja328
aznkuja328's Avatar
A video similar to this would not be bad at all Video Link: https://youtu.be/3xcSUIeYqwU
not a problem!
Old 03-27-2015, 05:29 PM
  #59
Jimmy-D
Jimmy-D's Avatar
So you are getting their Bypass Pipe Set?? If so, I am very interested in how you like it. Please post sound bites an pictures.
Old 03-27-2015, 05:30 PM
  #60
aznkuja328
aznkuja328's Avatar
Akra is making the same claim of 20 hp on their Evolution Race setup, but it occurs at 3,950 RPM and 11 hp increase in peak hp at 8,000. I'm assuming there is some inefficiency in the stock setup that they both correct + the valves being gone. I don't know exactly when stock valves open, but I thought it was 4,000? It seems to make some sense that the biggest delta without the valves is right before they would normally open.
I think the power is increased with the hi-flow cats in both the akrapovic and cargraphic headers or simply the removal of cats.
can he elaborate on his claim? where is the dip and how can the parallel flowing flap create that dip? with that said, will header cut out make the most power in the whole rpm range?
Quick Reply: exhaust / bypass - which one to choose?
