991 GT3 Oversteer Setup
Hi guys,
What is the best setup for the car to be tail happy but still able to maintain the slides (not make the car too snappy)?
Softest sway bar front and firmest in the rear?
Received 5,388 Likes
Excessive tire dressing.
Summer tires in winter weather.
Sent from my iPhone using Rennlist
Yikes, why do I have a feeling we're going to be reading about a wrecked GT3 very soon? Setting up a car for ill handling is a TERRIBLE idea. If you can't hang the tail out with your driving skills in stock form, then you more than likely you have no place hanging the tail out period. Not trying to be mean, just saying, focus on your driving skills better and then being able to slide the rear around and rotate the car will be simple. The ONLY reason that I could see wanting to set up a car like that is to shoot videos of the car rotating at slow speeds.
Because of the 911's rear engine location and weight distribution, the 911 is always going to be prone to snap oversteer: This is why you will never see a 911 drift car: the heavy front engine, rear wheel drive layout is much better for tail-out control, and consequentially, much slower lap times. This is of course, part of the charm of the 911: it is a much more complex and tricky car to drive, but once a driver learns how to exploit it, can end up embarrassing much more powerful cars on the racetrack.
ALL THAT BEING SAID, the GT3 has a very adjustable suspension, and it does come from the factory tuned specifically to have a small amount of understeer, to keep inexperienced drivers safe. While there are much better sources on this board for information on GT3 chassis tuning, I believe a good start would be to have the car aligned so that there is at least -1.5 degrees of negative camber in the front, and to set your front sway bar to it's softest setting, and the rear to the hardest. This will be MORE than enough of a change to the balance for a skilled driver to be able to get the tail out, and keep it out.
I hope that helps.
As some of the other guys here have already mentioned, setting up the GT3 specifically to oversteer is a bad idea for several reasons, but I wanted to give you a bit more basic information.
I hope that helps.
I hope that helps.
in several heavily crashed GT3s.
Until the 991 GT3RS proves its anticipated performance, IMHO, I’m convinced the 991 GT3 is the best Track Porsche ever to
be road licensed. A 2015 GT3 was recently Track tested around Willow Springs by Randy Pobst for Motor Trend Magazine.
http://www.motortrend.com/roadtests/...t3_first_test/
Randy noted "The turn-in is so accurate,” Pobst said. “Could be the best I’ve ever felt in a 911. The rear will let go in the middle of a corner."
Other quotes from the road test:
"Hoping for a balance between straight-line speed and cornering performance, Porsche delivered the car’s manually adjustable suspension and wing setup rather conservatively. As such, the GT3 had a tendency to lift-throttle oversteer on the figure eight, foot-wide Cup tires be damned. Although it was great fun to drift the car around, it was obvious that, tuned for more grip and less oversteer, the GT3 would be noticeably quicker around the track and likely perform even better on the skidpad."
"As we found during instrumented testing, Pobst agreed the car could do more with a bit less oversteer."
I noticed the same tendency that Pobst did after a few Track days and addressed the oversteer tendency by working with Max Crawford and his Race Engineers at Crawford Composites. After several months of development he developed a
larger and more effective Wing similar to the new GT3RS which reduces oversteer and keeps the Rear End more firmly “Planted” in high speed corners and clears the view to the rear also. You can see the new wing mounted on my Avatar.
FMI: David Cooper (704) 483-4175 http://crawfordcomposites.com
Was just curious if someone had tried different setups for such situations. A video I watched on youtube said that as the porsche changed the setup, the car was less oversteery.. I think it was motortrend or some other show. That's why I was curious.
Location: The way to hell is paved by good intentions “Wenn ich Purist höre...entsichere ich meinen Browning” "Myths are fuel for marketing (and nowadays for flippers too,,,)" time to time is not sufficient to be a saint, you must be also an Hero
u don t need to change the setup
if u have a 991 GT3 you ll find pushing both the paddles will
make the car drifting
be ready with your front wheel
have fun
have fun
I agree with your comments completely. Understeer is far easier to control than the snap oversteer which has already resulted in several heavily crashed GT3s. Until the 991 GT3RS proves its anticipated performance, IMHO, Im convinced the 991 GT3 is the best Track Porsche ever to be road licensed. A 2015 GT3 was recently Track tested around Willow Springs by Randy Pobst for Motor Trend Magazine. http://www.motortrend.com/roadtests/...t3_first_test/ Randy noted "The turn-in is so accurate, Pobst said. Could be the best Ive ever felt in a 911. The rear will let go in the middle of a corner." Other quotes from the road test: "Hoping for a balance between straight-line speed and cornering performance, Porsche delivered the cars manually adjustable suspension and wing setup rather conservatively. As such, the GT3 had a tendency to lift-throttle oversteer on the figure eight, foot-wide Cup tires be damned. Although it was great fun to drift the car around, it was obvious that, tuned for more grip and less oversteer, the GT3 would be noticeably quicker around the track and likely perform even better on the skidpad." "As we found during instrumented testing, Pobst agreed the car could do more with a bit less oversteer." I noticed the same tendency that Pobst did after a few Track days and addressed the oversteer tendency by working with Max Crawford and his Race Engineers at Crawford Composites. After several months of development he developed a larger and more effective Wing similar to the new GT3RS which reduces oversteer and keeps the Rear End more firmly Planted in high speed corners and clears the view to the rear also. You can see the new wing mounted on my Avatar. FMI: David Cooper (704) 483-4175 http://crawfordcomposites.com
I am actually a professional driver... You can find my page on facebook...
May I ask what form of professional racing your in? Second- shouldn't you or your sponsor knows what to do rather than rely on a rl board what makes a 911 oversteer? It really sounds weird when you to go to a forum and asked how to make it oversteer since you're a professional driver-doesn't make sense. Mike
