Track App?
#47
The latest is I just don't use it. The data points are interpolated from 1hz, not real, so the timing isn't accurate unless you get an external GPS or buy the stupid beacon. Couple that with really bad bugs and the inability to export video and you have the proverbial nail in the coffin. I have a cool red face clock though that matches my belts and cage...
#49
^^^ I agree. I mentioned the issue to my dealer and got the deer in the headlight look.
Que in the sound of crickets.......... " crickets " " crickets"
That's about as far as the fault finding went. No one at the dealership knows anything about the app or the option.....
So I chalked it up as another life lessons learned..... Won't be getting that again.
#52
Chrono:
Dumbest. Option. Ever.
IMHO of course!
IMHO of course!
#53
To get a view from inside the car so you can see you stearing as well as outside the front window, where are you all finding is the best location for the camera be it gopro, smarty ect?
Last weekend at the track, m aim dl worked perfectly, the go pro on the front toe hook using the rennline, perfect but when I used the suction cup for the go pro inside back window, not good. I couldn't see anything outside of the front window with the sun.
Sugestions?
Sugestions?
#54
Aim DL OBD2 Connections
For those of you who have the Solo DL installed via OBD2 like Joe mentioned, could you please post up some pics of your install? Was it DIY?
Thanks in advance! Father's day is coming up....
#55
Not much to show. You plug into the obd2 port and suction cup mount the display onto your windshield. Done.
#56
Do you know if there's an easy way to sync GoPro video with the AIM data?
#57
There is no 'easy' way to synce gopro video with AiM. I use dashware. It takes practice before it becomes easy.
#58
PCNA reply.
I spoke to PCNA about issues with track precision app on Android. Here is the reply:
"I wanted to make you aware that we have forwarded this concern to the appropriate department and they are aware of the issue. Unfortunately, I am unable to provide when the next update will be available. Please make sure to adjust your settings in your phone to automatically update the Precision Driving App so the program is updated as soon as a newer version is available. "
#59
With Android, every phone or tablet manufacturer can put in weird OS variations that cause no end of testing issues. Because it is so difficult and expensive to buy one of every Android device ever manufactured and then thoroughly test on every one, some Android problems can go undiscovered for many moons. Then, the developer tries to replicate the field problem on a less than complete set of devices and can't find any problem in their testing. It's horrible. Been there, done that.
Android is great, except when it isn't. Apple's iOS may be not everyone's cup of tea, but there are NO undocumented OS consistency problems against which to test.
I wish you and Porsche very good luck in finding and fixing your app problem. You may need it.
